DWL-900APEOL EOS
Wireless 2.4GHz (802.11b) Access Point
Description
The D-Link DWL-900AP is an IEEE 802.11b Wireless Access Point with point-to-point bridging capability that provides an easy solution for connecting two locations through  a wireless connection. The DWL-900AP utilises the 2.4 GHz Direct Sequence Spread Spectrum (DSSS) at 11Mbps with either ”point-to-point bridging” or ”point-to-multipoint bridging”. In addition, the DWL-900AP provides an option to be configured as a client Access Point instead of a bridge. The DWL-900AP can be managed remotely via the SNMP (Simple Network Management Protocol) Manager Software. In addition, a USB port is provided for flexibility in configuring the device.
In bridge mode, the DWL-900AP can connect directly to another DWL-900AP to extend the area of coverage for the wireless network. In a network with a DHCP server, the DWL-900AP will automatically obtain an IP adress. The DWL-900AP comes with one external detachable antenna. The DWL-900AP implements 128-bit WEP encryption (Wired Equivalent Privacy) to ensure a secure data network connection.
General features
 Standards
-IEEE 802.11b (Wireless LAN)
-IEEE 802.3 (Ethernet)
Interface
-10Base-T Ethernet, RJ-45 connector
Radio Frequency Range
-2400 ~ 2497 MHz ISM band
Modulation
-Direct Sequence Spread Spectrum
Data Rate
-1Mbps DBPSK, 2Mbps DQPSK, 5.5Mbps CCK, 11Mbps CCK
Number of Channels
-11 channels for USA
-13 channels for Europe
-4 channels for France
Data Security
- 64-bit and 128-bit WEP
Transmit Power
-12.5dBm typical
Receiver Sensitivity
- Typical -79dBm for 11Mbps @ 8 % PER (Packet Error Rate)
LED Indicators
-Power : power indicator
-Link : Ethernet link indicator
-WLAN: Wireless link indicator
Power Input
-DC 5V, 1A ~2A
-Use external AC power adapter
Antenna
One External 2.5dB gain antenna w/ reverse SMA connector
Operating Modes
- Access Point
- Wireless Bridge
- Point to Point
- Point to Multipoint
- Client AP
Roaming
- Among Access Points on the same subnet
Management
- SNMP Manager to manage wireless LAN, network connection and client access control
- USB Configuration
- TFTP Client for firmware upgrade
- Set IP Session (ARP/ping
- DCHP client
Certificates
Order info
Wireless LAN Access Point
DWL-900AP
    IEEE 802.11b compliant wireless access point. Optional external antennas will be available in the future.
Pictures
DWL-900AP
Front view
Downloads
Support Resources
