DBT-320EOL EOS
Bluetooth USB Printer Adapter
Description
Bluetooth Personal Area Network
The DBT-320 allows you to add a printer to your Bluetooth Personal Area Network (PAN) for communication between all your personal mobile devices. The DBT-320 supports standard Bluetooth profiles for printing including the Hardcopy Cable Replacement Profile (HCRP), Serial Port Profile (SPP), and Object Push Profile (OPP), which mean printing compatibility with virtually all Bluetooth-enabled mobile devices. It gives you the convenience of wireless printing from your PDA, mobile phone, laptop, and computers.
Convenient & Low-Cost Wireless Connection for Home and Office
The DBT-320 is great for home and of fice use, freeing you from cables and wires. It is based on a low-cost, short-range radio link, connecting many types of digital devices such as your computers and mobile phones, without a single cable in sight, giving you more freedom to roam about freely. As the DBT-320 utilizes a radio-based link, it does not require a line-of-sight connection in order to communicate with devices, something needed when using an Infra-red connection. This allows you use your laptop in one room and send a document to the printer in another room some distance away. In order to print, your Bluetooth-enabled computer, PDA or mobile phone simply has to come within a 10-meter range of your printer.
General features
Certificates
Order info
Pictures
DBT-320
Front view
Downloads
Support Resources
