Quick find
Product features:
OUTDOOR OMNI-DIRECTIONAL ANTENNA
Description:
OPTIMAL PERFORMANCE
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna is designed to be used in conjunction with devices at the 2.4GHz frequency, and compliance with the b and g standards. It offers a powerful omni-directional signal at a high 12dBi gain that can effectively redistribute a wireless signal to multiple remote locations at a wide range from an access point or bridge.
CONVENIENCE OF FLEXIBILITY
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna features a very durable build that grants users with great fexibility. Its waterproof design provides users with the facility of choosing placement in or outdoors. The antenna also includes an N-Type to RP-SMA adapter cable for added compatibility, and a surge protector to withstand against the outdoor elements.
SIMPLE WIRELESS SOLUTION
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna is ideal for operating in modes such as multi point-to-point WDS, access point, and others that require a wide coverage range with its built-in high gain antennas. This is a cost effcient solution, especially when setting up a comprehensive hub in hot-spot locations.
Products | Support  | News  | About |
