DSL-504T/RUEOL EOS
ADSL Router for Home/SOHO
Description
High-Speed Broadband Internet Connection
With this router, you can easily connect to your ADSL broadband line for Internet access in your office or at home. This device automatically creates an IP number and assigns for each user, simplifying everyone's logon operation.
Built-in ADSL Interface and Ethernet Switch Ports
A standard-based ADSL modem in built into this router, making connection to the Internet a breeze. The router also incorporates four 10/100Mbps Ethernet switch ports, providing ready connection for workstations and servers, while saving you the cost and trouble of installing a separate Ethernet switch.
Network Security
The router provides NAT protection for your office and home users from any Internet intruders and hackers, plus VPN pass-through for extra security. It also blocks and redirects certain ports to limit the services that outside users can access your network. Virtual server mapping is used to re-task services to multiple servers. This router can be set to allow separate FTP, Web, and Multiplayer game severs to
share the same Internet-visible IP address while still protecting your servers and workstations from hackers.
DMZ Host to Open Public Domain
The router supports constricted DMZ to redirect unknown packets to a dedicated server/PC behind the router, enabling a client (such as a Web server) to fully expose it to the Internet and ensure complete Internet application compatibility. This allows you to set up web sites and e-commerce business from your office while maintaining protection for the rest of your office LAN.
General features
Router
Interface
- 1 RJ-11 ADSL port
- 4 RJ-45 10/100BASE-TX Fast Ethernet LAN switch ports with auto MDI/MDIX
Routed Packet Type
IP packets
Routing Protocols & Methods
- RIP v1/v2 and static routing
- Dynamic routing
DHCP Support
- DHCP server (for automatic IP assignment)
- DHCP Client
Security
- VPN support: PPTP/L2TP/IPSec pass-through
- Network Address/Port translation (NAPT)
- Authentication: PAP and CHAP
- DoS (UDP/TCP), detection of known attacks
- SPI firewall protection
- Web login password authentication
Configuration & Network Management
- HTTP server for web-based management
- Remote management through Telnet or HTTP
- System logs
- Support UPnP 1.0
- Configuration backup and restore
- Factory reset
Statistics Monitoring
Ethernet, ATM and ADSL statistics
Diagnostic LEDs
- Power
- Status (system)
- ADSL Link/Act
- Ethernet Link/Act
Built-in ADSL Modem
Standards
- ADSL standards: ANSI T1.413 Issue 2, ITU G.992.1 (G.dmt) Annex A, ITU G.992.2 (G.lite) Annex A
- ADSL2 standards: ITU G.992.3 (G.dmt.bis) Annex A, ITU G.992.4 (G.lite.bis) Annex A
- ADSL2+ standards: ITU G.992.5 Annex A
- Auto-handshake: ITU G.994.1 (G.hs)
Data Rates
- G.dmt: 8Mbps downstream, 832Kbps upstream
- G.lite: 1.5Mbps downstream, 512Kbps upstream
- ADSL2: 12Mbps downstream, 1Mbps upstream
- ADSL2+: 24Mbps downstream, 1Mbps upstream
Performance
Passed DSL Forum TR-048 Performance Criteria
ATM/ADSL
- ATM Cell format ITU-T Rec. I.361
- ATM Adaptation Layer AAL5
- ATM signaling ATM Forum UNI3.1/4.0
- OAM support F4/F5 Loopback
- ATM QoS (Traffic Shaping) UBR, CBR, VBR
Bridged/PPP Support
Bridged Ethernet over ATM
- Classical IP over ATM
- PPP over ATM
- PPP over Ethernet
Certificates
Order info
Pictures
DSL-504T/RU
Front view
Downloads
Support Resources
