DI-714P+EOL EOS
802.11b+ Wireless Cable/DSL Router With 4-Port Switch & Print Server
Where to buy
Description
Simplified, Cost-saving Broadband Internet Connection
The DI-714P+ is designed for the office and public areas like hotels, airport lounges and convention halls. It allows easy sharing of broadband Internet through a DSL or cable modem from anywhere without the need for wiring. At the public sites, paying customers wishing to access the Internet can be easily added to your network. To let everybody logon, this device automatically creates and assigns an IP
number for each user, simplifying every one's logon operation.
Ready Connection
With built-in wireless LAN, 10/100Mbps switch and print server functions, the DI-714P+ provides ready connection for mobile users, workstations, servers and network printers, with or without the network wires. The built-in functions save you the cost and trouble of installing a separate Access Point, Ethernet switch and print server.
Enhanced Wireless Speeds
At 22Mbps, the DI-714P+ provides 802.11b+ wireless LAN users a high data transfer rate within the industry standard. Wireless LAN speed is double the 11Mbps normally found in other 2.4GHz wireless devices, but nevertheless full compatibility with 11Mbps 802.11b devices is maintained.
Network Security
The DI-714P+ provides NAT protection for your users from Internet intruders and hacker attacks, plus VPN pass-through for extra security. It blocks and re-directs certain ports to limit the services that outside users can access your network. Virtual Server Mapping is used to re-task Services to multiple servers. The router can be set to allow separate FTP, Web, and Multiplayer game servers to share the same Internet-visible IP address while still protecting your servers and workstations from hackers. Protection for wireless users is provided through a 256-bit strong WEP data encryption scheme.
DMZ Host to Open Public Domain
You can configure any of the built-in LAN ports to function as a DMZ port. A DMZ setting can be applied to a single client (such as a Web server) behind the router to fully expose it to the Internet and ensure complete Internet application compatibility even if the specific port is not known. This allows you to set up web sites and e-commerce business from your office while maintaining protection for the rest of your office LAN.
Print Server for Windows, MacOS, Linux
You can directly attach a parallel printer to the built-in printer port to share this printer out. The DI-714P+ supports print files from Windows, MacOS and Linux, allowing Ethernet and wireless users to print web pages and other files on this printer.
UPnP Enabled for Compatibility
The DI-714P+ is designed for easy and robust connectivity among heterogeneous standards-based  network devices. Computers can communicate directly with the DI-714P+ for automatic opening and closing of UDP/TCP ports to take full advantage of security provided without sacrificing functionality of on-line applications.
General features
Certificates
Order info
Pictures
DI-714P+
Downloads
Support Resources
