DIR-456EOL EOS
3.5G/Ethernet Internet router with FXS port
Where to buy
Description
WIRELESS NETWORKING ON THE GO
The D-Link HSDPA 3.5G Residential Router allows users to access worldwide mobile broadband networks. Once connected, users can transfer data, stream media, send SMS messages, and make mobile phone calls. Simply insert your UMTS/HSDPA SIM card to share your 3.5G Internet connection through a secure 802.11n wireless network or using any of the four 10/100 Fast Ethernet ports.
Convenient Voice Features
While accessing your 3.5G Internet connection, you will still have the ability to answer incoming mobile calls and respond to SMS messages. An RJ-11 jack allows you to attach a standard analog phone for high-quality mobile calls over a GSM network. Enjoy the comfort and convenience of your favorite office phone anywhere you go.
ADVANCED NETWORK SECURITY
Keep your wireless network private and secure with advanced WPA/WPA2 wireless encryption. The DIR-456 utilizes dual-active firewalls (SPI and NAT) to prevent potential attacks across the Internet, providing you with a safe networking environment.
SIMPLE TO INSTALL AND USE
The 3.5G Mobile Communication Router can be installed quickly and easily almost anywhere. This router is great for situations where an impromptu wireless network must be set up, or wherever conventional network access is unavailable. The DIR-456 can even be installed in buses, trains, or boats, allowing passengers to check e-mail or chat online while commuting.
General features
GSM BAND (GSM/GPRS/EDGE)
• 850 / 900 / 1800 / 1900 MHz
• Power Class 4 (850 / 900 MHz)
• Power Class 1 (1800 / 1900 MHz)
UMTS/HSDPA BAND
• 850 / 1900 / 2100 MHz
• Power Class 3
Standards
• 802.11n
• 802.11g
• 802.11b
• 802.3
• 802.3u
Wireless Security
• 64/128-bit WEP (Wired Equivalent Privacy)
• WPA & WPA2 (Wi-Fi Protected Access)
FIREWALL
ANTENNA
3 Internal antennas
Ports
• 2 x LAN (RJ-45)
• 1 x WAN (RJ-45)
• 1 x Phone (RJ-11)
USIM SLOT
Standard 6-pin SIM card interface
Diagnostic LED
• Power
• Internet
• 3G Mode
• 3G Signal
• WLAN
• Phone
• SMS
• WPS
• LAN
• WAN
DIMENSIONS (L x W x H)
165 x 112 x 34 mm
Operating Temperature
0˚ to 40˚C (32˚ to 104˚F)
Operating Humidity
10%-90% (Non-condensing)
CERTIFICATION
• CE
• FCC
Certificates
Order info
DIR-456 3.5G/Ethernet Internet router with FXS port
Pictures
DIR-456
Вид сзади
Downloads
Support Resources
