Quick find
Product features:
Wireless N750 Dual Band Router
EOL
Description:
Extreme Speed with Dual Band Wireless N and Gigabit Technology
The D-link DIR-835 Wireless N750 Dual Band router allows you to check e-mail and browse the Internet using the 2.4GHz band while streaming High-Definition (HD) movies and other media on the 5GHz band all at the same time for smooth playback with no interruptions. The Gigabit ports of the DIR-835 allow users to reach peak connectivity speeds, and dual band technology supports both 2.4GHz & 5GHz wireless signals, making all of your network connections fast and reliable.
Powered by HD Fuel with Intelligent QoS
Harness the power of HD Fuel to watch movies and play online games with superior router technology. HD Fuel combines the speed and clarity of the 5GHz wireless band with an advanced QoS engine to create a high quality HD media experience. The DIR-835 uses D-link intelligent QoS Prioritization Technology to analyze and separate your wired and wireless traffic into multiple data streams so applications like VoiP, video streaming, and online gaming can be given priority. HD Fuel combines raw speed with this smart prioritization to give you an uninterupted multimedia experience.
Share a Multifunction Printer or a USB Storage drive
By using the SharePort Plus Network USB utility, users can share printing, scanning, and faxing functions across an entire office or home by simply connecting a multifunction USB printer. In addition, users can also connect a USB hard drive to create a shared storage space for computers and devices on the network, making it easy to share photos, documents, and media files with a home or office.
IPv6 Ready
The DIR-835 supports the IPv6 standard and is compatible with IPv6 equipment from other manufacturers. Users are able to upgrade to a 128-bit addressing system to directly connect to anyone around the world using a unique IP address. This router is capable of handling routing for both IPv4 and IPv6 networks simultaneously, providing forward and backward compatibility for a flexible router that meets your needs both today and tomorrow.
Products | Support  | News  | About |
