Product features:
Wireless AC750 Dual Band Router & Access Point |
Description:
Wireless Interface Using the DIR-806A device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 733Mbps1). Secure Wireless Connection The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM. Advanced Capabilities of Wireless Network Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN2. Security The wireless router DIR-806A includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN. In addition, the gateway supports IPsec and allows to create secure VPN tunnels. Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices. Easy configuration and update You can configure the settings of the wireless router DIR-806A via the user-friendly web-based interface (the interface is available in several languages). The configuration wizard allows you to quickly switch DIR-806A to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps. Also DIR-806A supports configuration and management via mobile application for Android smartphones. You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it. 1Up to 300Mbps for 2.4GHz and up to 433Mbps for 5GHz. 2For DIR-806A/C1 only. |
Support Resources
