DIR-510LEOL EOS
Wi-Fi AC750 Portable Router and Charger
Description
Connect, share, and charge your mobile devices anytime, anywhere, with D-Link’s DIR-510L Wi-Fi AC750 Portable Router and Charger. Share files, stream media, and browse the Internet with the superb speed and performance provided by the latest Wireless AC technology. Simply connect your laptop, smartphone, or tablet to the DIR-510L’s wireless network and it will take care of the rest. With the built-in high-capacity rechargeable battery, this mobile power station lets your devices perform strong all day long.
Wireless AC for Breakthrough Performance
The DIR-510L incorporates the latest Wireless AC750 technology for unprecedented range and data transfer performance to and from compatible Wi-Fi devices. By using dual bands to bypass radio congestion and interference, the router can deliver a total of 750 Mbps using the combined bandwidth of its 2.4 GHz and 5 GHz bands. Moreover, each band can operate as a separate Wi-Fi network, giving you the ability to customize your network according to your connectivity needs. You can even configure a guest zone to give visitors Internet access without giving them access to the rest of your network. Combined with support for Universal Plug and Play (uPnP) and a built-in DLNA server, you can stream your multimedia collection smoothly and securely across all your devices and appliances, including smart TVs, game consoles, and media PCs.*
mydlink SharePort™ – Share On the Go
Sharing audio, videos, and photos is a breeze with the DIR-510L. Using the mydlink SharePort and SharePort Mobile apps for mobile devices, you can upload, download, and stream multimedia and documents to and from a USB drive attached to your DIR-510L, from anywhere in the world! Simply download the app, register for a free mydlink account, connect to your DIR-510L, and you can start sharing your media files with your friends and family as long as you have access to the Internet.
Your Mobile Power Station
The DIR-510L’s built-in high-capacity 4000 mAh rechargeable battery not only powers the device itself, it also keeps your gadgets charged and ready to go. The device provides two USB ports so you can charge a device and share files from a USB drive at the same time. You no longer have to worry about your smartphone’s battery running out of juice while on-the-move. Simply connect your smartphone or high-power devices like iPads to the USB port to start charging anywhere, anytime.**
Easy to Set Up, Easy to Use
The DIR-510L includes a user-friendly interface that stores your connection details for you so you only have to enter them once. Whether you’re connected via your 3G/4G adapter for mobile Internet or to the Wi-Fi hotspot of your favorite cafe, the DIR-510L helps you keep all of your devices connected, automatically!
General features
Device Interfaces
• 802.11 a/b/g/n/ac Wireless LAN, up to 750 Mbps***
• WAN 10/100 Ethernet port
• WPS button
• Power switch
• Reset button
• USB 2.0 Type A port (1 A) for compatible 3G/4G adapters****, USB drive, or charging other devices
• USB 2.0 Type A port (0.5 A) for USB drive or DCS-300
• Power port (MicroUSB)
LEDs
• Power/Status
• Battery status
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11b
• IEEE 802.11g
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3x
• IEEE 802.3u
• USB 2.0
Internet Modes
• Broadband Router Mode
• Mobile Router Mode
• Wi-Fi Hotspot Mode
Power Modes
• On/Off/Charger*****
Wireless Frequency Range
• IEEE 802.11a: 5150 MHz ~ 5850 MHz
• IEEE 802.11b: 2400 ~ 2497 MHz in ISM band
• IEEE 802.11g: 2400 ~ 2483.5 MHz in ISM band
• IEEE 802.11n (2.4 GHz): 2400 ~ 2483.5 MHz in ISM band
• IEEE 802.11n (5 GHz): 5180 MHz ~ 5320 MHz, 5745 MHz ~ 5825 MHz
• IEEE 802.11ac (draft) (5 GHz): 5180 MHz ~ 5320 MHz, 5745 MHz ~ 5825 MHz
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n (5 GHz): 6.5 ~ 150 Mbit/s
Transmitter output power
• IEEE 802.11a:
  17 dBm (+/-1 dB) at 6-18 Mbit/s
  16 dBm m (+/-1 dB) at 24-36 Mbit/s
  14 dBm (+/-1 dB) at 48-54 Mbit/s
• IEEE 802.11b: 17 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  18 dBm at 6-18 Mbit/s
  16 dBm at 24-36 Mbit/s
  14 dBm at 48-54 Mbit/s
• IEEE 802.11n (5 GHz band):
  17 dBm (+/-1 dB) at MCS0
  17 dBm (+/-1 dB) at MCS1
  17 dBm (+/-1 dB) at MCS2
  17 dBm (+/-1 dB) at MCS3
  16 dBm (+/-1 dB) at MCS4
  16 dBm (+/-1 dB) at MCS5
  14 dBm (+/-1 dB) at MCS6
  14 dBm (+/-1 dB) at MCS7
• IEEE 802.11n (2.4 GHz band):
  18 dBm at MCS0
  18 dBm at MCS1
  18 dBm at MCS2
  18 dBm at MCS3
  16 dBm at MCS4
  16 dBm at MCS5
  14 dBm at MCS6
  14 dBm at MCS7
  21 dBm at MCS8
  21 dBm at MCS9
  21 dBm at MCS10
  21 dBm at MCS11
  19 dBm at MCS12
  19 dBm at MCS13
  17 dBm at MCS14
  17 dBm at MCS15
• IEEE 802.11ac (5 GHz band):
  17 dBm at MCS0
  17 dBm at MCS1
  17 dBm at MCS2
  17 dBm at MCS3
  16 dBm at MCS4
  16 dBm at MCS5
  14 dBm at MCS6
  14 dBm at MCS7
  13 dBm at MCS8
  13 dBm at MCS9
Receiver sebsitivity
• IEEE 802.11a:
  –91 dBm at 6 Mbit/s
  –90 dBm at 9 Mbit/s
  –89 dBm at 12 Mbit/s
  –87 dBm at 18 Mbit/s
  –83 dBm at 24 Mbit/s
  –80 dBm at 36 Mbit/s
  –76 dBm at 48 Mbit/s
  –75 dBm at 54 Mbit/s
• IEEE 802.11b:
  –86 dBm at 1 Mbit/s
  –86 dBm at 2 Mbit/s
  –85 dBm at 5.5 Mbit/s
  –84 dBm at 11
• IEEE 802.11g:
  –84 dBm at 6 Mbit/s
  –84 dBm at 9 Mbit/s
  –83 dBm at 12 Mbit/s
  –80 dBm at 18 Mbit/s
  –78 dBm at 24 Mbit/s
  –74 dBm at 36 Mbit/s
  –70 dBm at 48 Mbit/s
  –69 dBm at 54 Mbit/s
• IEEE 802.11n:
  HT20
  -89 dBm at BPSK, encoding rate 1/2 (MCS-0)
  -87 dBm at QPSK, encoding rate 1/2 (MCS-1)
  -85 dBm at QPSK, encoding rate 3/4 (MCS-2)
  -84 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -80 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -76 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -74 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -73 dBm at 64-QAM, encoding rate 5/6 (MCS-7)
  HT40
  -86 dBm at BPSK, encoding rate 1/2 (MCS-8)
  -85 dBm at QPSK, encoding rate 1/2 (MCS-9)
  -83 dBm at QPSK, encoding rate 3/4 (MCS-10)
  -81 dBm at 16-QAM, encoding rate 1/2 (MCS-11)
  -78 dBm at 16-QAM, encoding rate 3/4 (MCS-12)
  -72 dBm at 64-QAM, encoding rate 2/3 (MCS-13)
  -71 dBm at 64-QAM, encoding rate 3/4 (MCS-14)
  -69 dBm at 64-QAM, encoding rate 5/6 (MCS-15)
  HT-20
  -84 dBm at 16-QAM, encoding rate /2 (MCS-3)
  HT-40
  HT-20
  -83 dBm at BPSK, encoding rate 1/2 (MCS-0)
  -82 dBm at QPSK, encoding rate 1/2 (MCS-1)
  -81 dBm at QPSK, encoding rate 3/4 (MCS-2)
  -77 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -74 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -72 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -69 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -68 dBm at 64-QAM, encoding rate 5/6 (MCS-7)
  HT-40
  -82 dBm at BPSK, encoding rate 1/2 (MCS-8)
  -82 dBm at QPSK, encoding rate 1/2 (MCS-9)
  -80 dBm at QPSK, encoding rate 3/4 (MCS-10)
  -77 dBm at 16-QAM, encoding rate 1/2 (MCS-11)
  -73 dBm at 16-QAM, encoding rate 3/4 (MCS-12)
  -68 dBm at 64-QAM, encoding rate 2/3 (MCS-13)
  -68 dBm at 64-QAM, encoding rate 3/4 (MCS-14)
  -66 dBm at 64-QAM, encoding rate 5/6 (MCS-15)
  HT-20
  -81 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -78 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -74 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -72 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -71 dBm at 64-QAM, encoding rate 5/6 (MCS-7)
  -66 dBm at 256-QAM, encoding rate 3/4 (MCS-8)
  HT-40
  -86 dBm at BPSK, encoding rate 1/2 (MCS-0)
  -84 dBm at QPSK, encoding rate 1/2 (MCS-1)
  -82 dBm at QPSK, encoding rate 3/4 (MCS-2)
  -78 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -76 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -71 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -70 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -63 dBm at 256-QAM, encoding rate 3/4 (MCS-8)
  -61 dBm at 256-QAM, encoding rate 5/6 (MCS-9)
  HT-80
  -81 dBm at QPSK, encoding rate 1/2 (MCS-1)
  -79 dBm at QPSK, encoding rate 3/4 (MCS-2)
  -75 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -72 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -68 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -66 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -65 dBm at 64-QAM, encoding rate 5/6 (MCS-7)
  -60 dBm at 256-QAM, encoding rate 3/4 (MCS-8)
  -58 dBm at 256-QAM, encoding rate 5/6 (MCS-9)
Antennas
• Internal antennas
Sharing Features******
• mydlink SharePort app
  • App supports iPhone®, iPad®, iPod touch®, and Android™ devices
  • Remote Access Mode: Access files through the Internet*******
  • Local Access Mode: Access files from any device connected to the DIR-510L
• SharePort Web Access support (Web browser)
  • Access files from any device connected to the DIR-510L
• SharePort Mobile app support for Windows® 8/RT devices
Security
• Wi-Fi Protected Access (WPA/WPA2)
• WEP 64/128-bit encryption********
• WPS 2.0 (PBC)
Advanced Features
• Guest Zone support
• IPv6
• Wi-Fi WMM Quality of Service (QoS)
• UPnP support
• DLNA Media Server**
Advanced Firewall Features
• MAC address filtering
Device Management
• User-friendly Web UI with desktop and mobile interfaces
Certificates
Order info
Pictures
DIR-510LA1
Back view
Back view
Left side view
Front view
Downloads
Support Resources
