DIR-615A/A1EOL EOS
Wireless N300 Router
Description
Wireless Interface
Using the DIR-615 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the wireless connection rate up to 300Mbps).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-615 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-615 via the user-friendly web-based interface (the interface is available in several languages).
The configuration wizard allows you to quickly switch DIR-615 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-615 supports configuration and management via D-Link Click'n'Connect mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
General features
				 Hardware
				 Processor
				 RTL8196D (390MHz)
				 RAM
				 32MB, DDR2
				 Flash
				 4MB, SPI
				 Interfaces
				 10/100BASE-TX WAN port
				4 10/100BASE-TX LAN ports
				 LEDs
				 POWER
				STATUS
				WLAN / WPS
				INTERNET
				4 LAN LEDs
				 Buttons
				 POWER button to power on/power off
				 RESET button to restore factory default settings
				 WPS button to set up secure wireless connection and enable/disable wireless network
				 Antenna
				 Two internal omnidirectional antennas (2dBi gain)
				 MIMO
				 2 x 2
				 Power connector
				 Power input connector (DC)
				 Software
				 WAN connection types
				 PPPoE
				 IPv6 PPPoE
				 PPPoE Dual Stack
				 Static IPv4 / Dynamic IPv4
				 Static IPv6 / Dynamic IPv6
				 PPPoE + Static IP / Dynamic IP (PPPoE Dual Access)
				 PPTP/L2TP + Static IP
				 PPTP/L2TP + Dynamic IP
				 Network functions
				 DHCP server/relay
				 Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				 Automatic obtainment of LAN IP address (for access point/repeater/client modes)
				 DNS relay
				 Dynamic DNS
				 Static IP routing
				 Static IPv6 routing
				 IGMP Proxy
				 RIP
				 Support of UPnP IGD
				 Support of VLAN
				 WAN ping respond
				 Support of SIP ALG
				 Support of RTSP
				 WAN reservation
				 Built-in UDPXY application
				 Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
				 Setup of maximum TX rate for each port of the router
				 Firewall functions
				 Network Address Translation (NAT)
				 Stateful Packet Inspection (SPI)
				 IP filter
				 IPv6 filter
				 MAC filter
				 URL filter
				 DMZ
				 Prevention of ARP and DDoS attacks
				 Virtual servers
				 Built-in Yandex.DNS web content filtering service
				 VPN
				 IPSec/PPTP/L2TP/PPPoE pass-through
				 Management
				 Local and remote access to settings
				 TELNET/WEB (HTTPS, HTTP)
				 Multilingual web-based interface for configuration and management
				 Support of Click'n'Connect application for Android smartphones
				 Notification on connection problems and auto redirect to settings
				 Firmware update via web-based interface
				 Automatic notification on new firmware version
				 Saving/restoring configuration to/from file
				 Support of logging to remote host
				 Automatic synchronization of system time with NTP server and manual time/date setup
				 Ping utility
				 Traceroute utility
				 TR-069 client
				 Wireless Module Parameters
				 Standards
				 IEEE 802.11b/g/n
				 Frequency range
				 2400 ~ 2483.5MHz
				 Wireless connection security
				 WEP
				 WPA/WPA2 (Personal/Enterprise)
				 MAC filter
				 WPS (PBC/PIN)
				 Advanced functions
				 Support of client mode
				 WMM (Wi-Fi QoS)
				 Information on connected Wi-Fi clients
				 Advanced settings
				 Guest Wi-Fi / support of MBSSID
				 Rate limitation for wireless network/separate MAC addresses
				 Periodic scan of channels, automatic switch to least loaded channel
				 Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				 Wireless connection rate
				 IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
				 Transmitter output power
				 802.11b
				 17dBm at 1, 2, 5.5, 11Mbps
				 802.11g
				 17dBm at 6, 9, 12Mbps
				16dBm at 18, 24Mbps
				15dBm at 36, 48, 54Mbps
				 802.11n
				 HT20/HT40
				16,5dBm at MCS0/1/2/8/9/10
				16dBm at MCS3/4/11/12
				15,5dBm at MCS5/13
				15dBm at MCS6/14
				14dBm at MCS7/15
				 Receiver sensitivity
				 802.11b
				 -82dBm at 1Mbps
				-80dBm at 2Mbps
				-78dBm at 5.5Mbps
				-76dBm at 11Mbps
				 802.11g
				 -85dBm at 6Mbps
				-84dBm at 9Mbps
				-82dBm at 12Mbps
				-80dBm at 18Mbps
				-77dBm at 24Mbps
				-73dBm at 36Mbps
				-69dBm at 48Mbps
				-68dBm at 54Mbps
				 802.11n
				 HT20
				-82dBm at MCS0/8
				-79dBm at MCS1/9
				-77dBm at MCS2/10
				-74dBm at MCS3/11
				-70dBm at MCS4/12
				-66dBm at MCS5/13
				-65dBm at MCS6/14
				-64dBm at MCS7/15
				HT40
				-79dBm at MCS0/8
				-76dBm at MCS1/9
				-74dBm at MCS2/10
				-71dBm at MCS3/11
				-67dBm at MCS4/12
				-63dBm at MCS5/13
				-62dBm at MCS6/14
				-61dBm at MCS7/15
				 Modulation schemes
				 802.11b
				 DQPSK, DBPSK, DSSS, CCK
				 802.11g
				 BPSK, QPSK, 16QAM, 64QAM with OFDM
				 802.11n
				 Physical Parameters
				 Dimensions
				 134 x 83 x 98 mm
			(5.3 x 3.3 x 3.9 in)  |
				 Weight
				 202 g (0.45 lb)
				 Operating Environment
				 Power
				 Output: 12V DC, 0.5A
				 Temperature
				 Operating: from 0 to 40 °C
				Storage: from -20 to 65 °C
				 Humidity
				 Operating: from 10% to 90% (non-condensing)
				Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 Router
				Power adapter DC 12V/0.5A
				Ethernet cable
				“Quick Installation Guide” (brochure)
Certificates
Order info
DIR-615A/A1   Wireless N300 Router
