DI-634MEOL EOS
Wireless 108G MIMO Router
Where to buy
Description
With the D-Link DI-634M wireless 108G MIMO router, you can create a robust wireless network that boasts powerful performance and extended coverage and enjoy the full benefits of wireless connectivity. Y ou can now deploy the next-generation wireless network with dramatic performance improvements.
This router uses D-Link's latest Smart Antenna MIMO (Multiple Input Multiple Output) technology to provide up to 8 times better radio signal coverage. Combined with wireless speeds of up to 108Mbps, this router allows you to effectively implement high-bandwidth applications such as audio and video streaming, on-line gaming and large file transfer over a wireless network.
Extended Wireless Operation Range. Operating on the 2.4GHz frequency band, the DI-634M sends information out over multiple high Gain antennas. Radio signals typically reflect off objects, creating multiple paths that in conventional radios cause interference and fading. The DI-634M uses these paths to carry more information, which is recombined on the receiving side by the MIMO algorithms. As a result, the DI-634M reduces "dead" spots and distributes strong wireless signals across farther distances with enough bandwidth to stream multimedia content and transfer large files at far higher rates.
Up to 108Mbps Wireless Speed. The DI-634M doubles the spectral efficiency compared with the current wireless network. The maximum non-Turbo data transfer rate for 802.1 1g networks is 54Mbps, though actual throughput is typically closer to 20Mbps to 30Mbps. Enhanced by the Turbo mode, the DI-634M can boost the typical raw wireless speeds to 108Mbps, or a real throughput 8 times faster than that of standard 802.11g equipment.
Investment Protection. With backward compatibility to 802.11g and 802.1 1b industry standards, the DI-634M can operate seamlessly with your existing wireless devices. You don't have to replace your current network devices to experience the full benefits of extended range and Turbo speeds of this wireless router.
Network Security.  The DI-634M provides NAT and Stateful Packet Inspection (SPI) firewall protection, as well as parental controls to monitor and maintain Internet usage. Combining these features with full system logging, Static DHCP, VPN pass-through, and Network Diagnostic Tools, this router ensures a fully protected network.
Wireless Security.  The DI-634M supports both standard WEP and advanced WPA-Personal (WPA-PSK) data encryption. Additional security features include MAC and IP filtering for limiting network access based on MAC Address or IP Address. To further prohibit intruders' access to your network, the DI-634M can also be configured to invisible mode so the network name (SSID) cannot be scanned by outside wireless clients.
Complete Wireless 108G MIMO Solution. D-Link offers a complete solution with wireless 108G MIMO adapters and routers. This allows you to obtain the best results with a true MIMO implementation on both ends of a connection.
General features
Certificates
Order info
Pictures
DI-634M
Downloads
Support Resources
