DIR-655EOL
Xtreme N Gigabit Router
Where to buy
Description
BEST-IN-CLASS FEATURES
The D-Link DIR-655 Xtreme NTM Gigabit Router is a draft 802.11n compliant device that delivers up to 14x faster speeds1 and 6x farther range  than 802.11g while staying backward compatible with 802.11g and 802.11b devices. Connect the Xtreme NTM Gigabit Router to a cable or DSL modem and provide high-speed Internet access to multiple computers, game consoles, and media players. Create a secure wireless network to share photos, f les, music, videos, printers, and network storage. Powered by Xtreme NTM technology and equipped with three external antennas, this router provides superior wireless coverage for larger homes and off ces, or for users running bandwidth-intensive applications. The DIR-655 also includes a 4-port 10/100/1000 Gigabit switch that connects Gigabit wired devices for lag-free network gaming and faster f le transfers.
INTELLIGENT QoS ENGINE
With D-Link’s Intelligent QoS Technology, wired and wireless traff c are analyzed and separated into multiple data streams. The DIR-655’s embedded WISH Stream Engine improves wireless media by moving time-sensitive tagged traff c to the front of the WMM queue and optimizing RF settings for optimal wireless throughput. WISH (Wireless Intelligent Stream Handling) automatically detects multimedia, VoIP and Online Gaming applications, requiring no user conf guration. It works transparently with other QoS technologies to immediately improve wireless media speed.
ADVANCED NETWORK SECURITY
The Xtreme NTM Gigabit Router supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or the Internet. Support for WEP, WPA, and WPA2 standards ensure that you will be able to use the best possible encryption regardless of your client devices. In addition, this Xtreme NTM Gigabit Router utilizes Dual Active Firewalls (SPI and NAT) to prevent potential attacks from across the Internet.
HARD DRIVE,mULTIFUNCTION PRINTER SHARING, 3G mOBILE INTERNET CONNECTION
TM Network USB Utility, you can connect an external hard drive or multifunction printer to the router’s USB port to share disk space, printing or scanning functions among family members or a group of users. This USB port also supports D-link 3G adapter connection, so you can connect your router to a 3G mobile service to provide Internet access to a group while travelling.
General features
STANDARDS
+ IEEE 802.11n (draft)
+ IEEE 802.11g
+ IEEE 802.11b
+ IEEE 802.3
+ IEEE 802.3u
+ IEEE 802.3ab
DEVICE INTERFACES
+ 802.11n (draft) Wireless LAN
+ 10/100/1000BASE-T Gigabit WAN port
+ 4 10/100/1000BASE-T Gigabit LAN ports
+ USB 2.0 port
ANTENNA TYPE
3 external 2dBi RP-SMA dipole antennas
SECURITY
+ 64/128-bit WEP
+ WPA & WPA2 (Wi-Fi Protected Access)
ADVANCED FIREWALL FEATURES
+ Network Address Translation (NAT)
+ Stateful Packet Inspection (SPI)
+ VPN Pass-Through/Multi-Sessions PPTP/L2TP/IPSec
QoS
+ QoS Engine for prioritizing traffc
+ WISH Stream Engine
DEVICE MANAGEMENT
+ UPnP support
+ DDNS support
+ Integrated Wireless Security Wizard
+ Windows Connect Now (WCN) support
+  Web-Based management using Internet Explorer v6 or later; Mozilla Firefox v2.0 or later; or other Java-Enabled browsers
+ Automatic frmware update notifcation
+ E-Mail notifcation for triggered events
SharePortTM FUNCTION SUPPORT
   -   Allows connection of external hard drive or multifunction printer to USB port
   -   Allows sharing of HD space, printing and scanning functions*
INSTALLATION
+ Quick Router Setup Utility
+ SharePortTM Network USB  Utility
+ Desktop or wall mount
MINIMUM SYSTEM REQUIREMENTS
+ Computer with:
   - Pentium 3 800GHz or better processor
   - 256MB RAM or higher
   -  Windows Vista, XP SP2, 2000, 2003 or
Mac OS X v10.4 or higher
   - CD ROM drive
   - SharePortTM Network USB Utility
RECOMMENDED SYSTEM REQUIREMENTS
For optimal wireless performance:
+   Rangebooster NTM 650 adapters (DWA-645)
LEDS
+ Power
+ Status
+ Internet / WAN
+ WLAN
+ LAN
+ USB
DIMENSIONS
120.5 x 198 x 32 mm (4.6 x 7.6 x 1.3 inches)
WEIGHT
341.5 grams (0.75 lb)
CERTIFICATIONS
+ FCC Class B
+ CE
+ IC
+ C-Tick
+ Wi-Fi b/g/n
+ WMM
+ Works with Windows Vista
Certificates
Order info
DIR-655   802.11n Wireless Gigabit Router with 4-ports 10/100/1000 Base-TX switch
Pictures
DIR-655
Вид сзади
Downloads
Support Resources
