DE-220PCTEOL EOS
ISA-bus PnP Ethernet Adapter with Combo 10BASE-T/BNC interface
Where to buy
Description
Plug and Play
Most PCs manufactured today support Plug-and-Play (PnP) ISA industry specifications. These adapters support PnP , so on PnP systems, the only thing to do is drop the adapter into an ISA slot. During bootup, the computer examines all installed hardware and assigns necessary, conflict-free resources for the adapter.
Easy to Use
For older PCs that do not support PnP , these adapters provide an easy-to-use menu-driven program with on-line help that makes configuration setup an effortless task.
Most Economic Choise
With very low prices, these adapters are the most economic choice for connecting desktops ona 10Mbps network.
General features
Certificates
Order info
Pictures
DE-220PCT
Вид сверху
Downloads
Support Resources
