Quick find
Product features:
Multifunction Wireless VoIP Router with 2 FXS Ports, 1 USB Port and Built-in 4-port Switch
Description:
SIP Telephony
The VoIP router is equipped with two FSX ports which allow connection of analog phones for calls via Internet.
USB Port
The router is equipped with a USB port for connecting a USB modem,which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
Wireless Interface
Using the DVG-N5402SP device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). The router can operate as an access point for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps). You can easily switch the router's wireless network on/off by pressing the WLAN button located on the cover of the device.
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
Security
The wireless router DVG-N5402SP includes a built-in firewall. The advanced security functions minimize threats of hacker attacks and prevent unwanted intrusions to your network.
Configuration and Management
You can configure and manage the settings of the wireless router DVG-N5402SP via the user-friendly web-based interface (the interface is available in several languages).
Products | Support  | News  | About |
