DVG-G5402SPEOL EOS
VoIP Wireless Router
Description
INTERNET PHONE MADE FOR HOME & SOHO
The D-Link DVG-G5402SP VoIP Wireless Router allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network technology with advanced communication features, and is compatible with industry-wise phone service. This VoIP Router connects you to up to two ordinary phone sets to let you make phone calls. Router connects you to up to two ordinary phone sets to let you make phone calls.  connects you to up to two ordinary phone sets to let you make phone calls.
SUPERIOR VOICE QUALITY
The DVG-G5402SP incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference, phone book, speed dialing and hot lines to make it convenient to dial out or answer phone calls.
COMPLETE SECURITY
The DVG-G5402SP supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides a lifeline phone port to relay your incoming and outgoing phone calls to PSTN in case when a power down occurs. This guarantees that your phone connection will always be available.
INTEGRATED WIRELESS 4-PORT ROUTER
The DVG-G5402SP provides a 802.11g standard wireless LAN and router function with built-in NAT/DHCP server to permit multiple computers to share an Internet broadband line. With four integrated Ethernet ports, four Ethernet-enabled computers and network devices can also connect to the DVG-G5402SP to log on to the Internet.
General features
DEVICE INTERFACES
+  2 RJ-11 FXS phone ports with polarity reversal detection and generation
+  1 RJ-11 PSTN lifeline phone port
+  1 RJ-45 10/100BASE-TX WAN port  with auto-MDI/MDIX
+  4 RJ-45 10/100BASE-TX LAN ports with auto-MDI/MDIX
GENERAL SIP FEATURES
+  Individual account per port or share account for all ports
+  Caller ID Delivery
+  Direct IP-to-IP Call without SIP Proxy
+  Digit Map and Phone Book
+  DNS SRV, SIP SRV
+  E.164 Numbering (with ENUM exception rule)
+  Group, Pick Up
+  Hot Line, Warm Line
+  Interactive Voice Response confguration (IVR)
+  Message Waiting Indication (SUBSCRIBE)
+  Visual Message Waiting Indication (SUBSCRIBE)
+  Music on hold
+  Outbound Proxy
+  SIP INFO
+  Three way conferencing (Ad Hoc mode, Media Server required)
+  Basic Call Features (Supplementary)
  -  ANONYMOUS CALL BLOCkING
  -  CALL BLOCk AND FILTER BY CALLER IP ADDRESS
  -  CALL FORWARDING - BUSY
  -  CALL FORWARDING - NO ANSWER
  -  CALL FORWARDING - UNCONDITIONAL
  -  CALL HISTORY (CALL STATUS)
  -  CALL HOLD
  -  CALL PICk UP
  -  CALL PARk AND RETRIEVE (PROXY SUPPORT)
  -  CALL TRANSFER (PROXY SUPPORT)
  -  CALL WAITING
  -  CALLING NAME AND TIME (FSk)
  -  DO NOT DISTURB
  -  CALLER ID BLOCkING
AUDIO FUNCTIONS
+  Adaptive Jitter Buffer
+  Adaptive Echo Canceller
+  Automatic voice/fax/data Detection and Switching
+  Auto Gain Control (AGC)
+  Codec: G711 μ/A-law, G729A/B/AB, G.723(6.3/5.3 kbps), G.726
+  Comfort Noise Generation (CNG)
+  DTMF Detection and Generation
+  In-band or Out of Band DTMF event
+  Packet Loss Concealment
+  Support voice/fax/modem (up to 33.6kbps) over IP
+  T.30 FAX bypass thought G.711
+  T.38 real time FAX up to 14.4 kbps
+  Voice Activity Detection (VAD)
+  Caller ID detection and generation: DTMF, FSk-BellCore, FSk-ETSI
CONFIGURATION/MANAGEMENT
+  Automatic Provisioning (exclusion from TR069/TR104 option)
+  WEB User Interface
+  TELNET User Interface
+  Confguration Backup and Restore through Web UI
+  Call History (Received Call/Disabled Call/Missed Call)
+  Flat Call Detail Record output (CDR)
+  Network Time Protocol time synchronization (Default by D-Link NTP)
+  Password Security (Web UI and TELNET)
+  Ping Test
+  Reset confguration to factory default
+  SNMP v2 (exclusion from TR069/TR104 option)
+  Static and Default routes
+  System status
+  TFTP/FTP/HTTP Client for frmware upgrade
+  TR069/TR104 Client support (optional)
WAN CONNECTION
+  Big Pond Client
+  DHCP Client
+  PPPoE Authentication by PAP/CHAP
+  PPTP Client
+  Static IP
QoS
+  DiffServ (DSCP) or ToS IP Precedence tagging (WAN)
+  LAN port rate limit
+  WAN port rate limit (in step of 64kbps)
+  WAN port priority queue: RTP frst
+  802.1Q and 802.1P Tagging (1 VID for VoIP traffc, 1 VID for LAN traffc)
NAT TRAVERSAL
+  STUN Client
+  DDNS Client
+  SIP and RTP Port Range Designation
+  Static Route
SECURITY
+  Built-in Firewall
+  IP Filtering
+  Port Filtering
+  MAC Filtering
+  Virtual Server
+  DMZ
+  Denial of Service Protection (DoS)
+  MD5 Authentication for SIP
+  Two privilege login control: Administrator and User
+  VPN Pass-through with Multiple Sessions (IPSec, PPTP, L2TP )
WIRELESS LAN
+  802.11 b/g standard
+  Supports up to 64 client associations
+  Automatic RF channel selection
+   Wireless security: access control based on MAC addresses, 64/128-bit WEP data encryption, WPA/WPA support
Certificates
Order info
DVG-G5402SP    Wireless Internet Router with VoIP Gateway
Pictures
DVG-G5402SP/A1
Front view
Back view
Downloads
Support Resources
