שאלה: Какие из ISDN Terminal Adapter (TA or ISDN modem) протестированы и работают с DP-602 /DP-802/DP-601M
תשובה:
Suggested ISDN Terminal Adapter (TA or ISDN modem) that tested working on DP-602 /DP-802/DP-601M
    1. Eicon Diva TA ISDN
      Please refer to the setup product manual
    2. E-Tech TA128A
    3. Motorola BitSurfer & BitSurfer Pro
    4. NTT-IT ThunderCard / TA DD1280 ISDN
    5. Zyxel Omni-net, Zyxel Omni TA 128
      ATB40&J0 for 64K connection and
      ATB40&J3 for 128K connection.
    6. Acer - Acer ISDN T30
      64K :AT&FS0=0E0V1W0%C0%A2=95%P0=0\T0\Q3
      128K:AT&FS0=0E0V1W0%C0%A2=95%P0=1\T0\Q3
      In IS-Admin, select "Configuration" -> "WAN Port", then replace default string in "Initial String" item with above mentions.
    7. Ausucom - TA-200ST
    8. CyberVision Power128
      Может использовать "Standard" Init String в DP-x02 (не нужно изменять!)
