חיפוש מהיר
תכונות המוצר:
מתג לארון 24 פורטים 10/100Mbps בנוסף 2 פורטים ג'יגהביט
מאפיינים כללים:
Interface
• Fast Ethernet:
100 Mbit / s (half duplex)
200 Mbit / s (duplex)
• Gigabit Ethernet:
2000 Mbit / s (duplex)
Protocol
• CSMA / CD
Data transfer rate
• Ethernet:
10 Mbit / s (duplex)
20 Mbit / s (half duplex)
• Fast Ethernet:
• Gigabit Ethernet:
Topology
• Star
Network Cable
• 10BASE-T:
UTP Cat. 3, 4, 5 (100 m max.)
EIA/TIA-568 100-ohm STP (100 meters max.)
• 100BASE-TX, 1000BASE-T:
UTP Cat. 5, Cat. 5e (100 m max.)
Number of Ports
• 24-port 10/100 Mbit / s
• 2 10/100/1000 Mbit / s
Advanced Interface
• Autodetect cable polarity MDI / MDI-X on each port
Indicators On the device
• Power (Power)
• Status (Status)
At the port:
• Link / Activity (State / Active)
• Speed ​​of 100 Mbit / s (ports 10/100 Mbit / s)
• Speed ​​of 100 Mbit / s and 1000 Mbit / s (ports 10/100/1000 Mbit / s)
Switching Method
• Store-and-forward
The switch fabric
• 8.8 Gb / s
MAC-address table
• 8K entries per device
The study of MAC-address
• Automatic updating of MAC-address table
Speed ​​packet filtering
• 10BASE-T: 14,880 frames / sec per port (half duplex)
• 100BASE-TX: 148,810 frames / sec per port (half duplex)
• Gigabit Ethernet: 1488,100 frames / sec per port
Speed ​​packet switching
RAM Buffer
• 320Kbayt on device
נתונים פיזיים
Power
• 100 - 240 VA, 50/60 Hz, 0.3A
• Internal universal power supply
Power consumption
• 15.68 Watt
Fan
• 40 x 40 mm with a DC power supply x 1
Operating Temperature
• 0-40C
Storage temperature
• 10-70C
Humidity
• 5% - 90% non-condensing
Dimensions
• 440 x 200 x 44 mm
• The standard width for 19-inch rack, 1U
Weight
• 2.8 kg
Certificates EMC
• FCC Class A
• CE Class A
• VCCI Class A
• C-Tick
Safety Certifications
• CUL
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
