תאור
D-Link DGS-3700 series Metro Switches are designed & purpose-built for Metro Ethernet services for Telecom/Service Providers. Its design is based on feld proven experience learnt from multiple Ethernet deployment in Telecoms/Carriers. It supports wide variety of technologies including Ethernet, OAM (Operations, Administration and Maintenance), Double VLAN (Q-in-Q), QoS and Triple play services demanded by Carrier Ethernet networks.
Product Overview
D-Link DGS-3700 series is D-Link Metro switch family optimized for the Ethernet-to-the-Home (ETTH) and Ethernet-to-the-Business (ETTB) services. It comes ready with Service Provider-Friendly hardware, robust software & security features, OAM manageability functions and Triple-Play Services.
D-Link DGS-3700 series comes with:
- D-Link DGS-3700-12 with 8-Port 10/100/1000Mbps + 4 Combo Copper/SFP L2 Management Switch
- D-Link DGS-3700-12G 8-Port SFP + 4 Combo Copper/SFP L2 Management Switch
The SFP Gigabit ports support a wide variety of SFP tranceivers. They include 100Base-FX, 1000Base-LX, 1000Base-SX, 1000BASE-SXM, 1000BASE-LHX, 1000BASE-ZX and Wavelength-Division Multiplexing (WDM) SFP transceivers.
Service Provider-Friendly Hardware
D-Link DGS-3700 series is designed to be deployed in compact and outdoor Telecom/Carriers cabinet. It has a compact form factor of 210 mm in depth in a 1U rack enclosure with operating temperature of up to 65?C. Furthermore, to simplify feld installation, troubleshooting and maintenance, it has all the access connection located on the front panel.
These include:
- 10/100/1000Base-T Ports or SFP Slots
- Modular AC/DC Power Supply
- Modular Fan
- Modular Dust Filter
- RS-232 console port
- RJ-45 OOB management port
- RJ-45 Alarm port
- Grounding
Robust Software & Security
D-Link DGS-3700 series provides extensive VLAN support including Double VLAN (Q-in-Q), Layer 2 Protocol Tunneling (L2PT), GARP/GVRP and 802.1Q to enhance network security and performance. Bandwidth Control can be fexibly set for each port using pre-defned thresholds to assure a committed level of service for end users. For advanced applications, per-fow bandwidth control allows easy fne-tuning of service types based on specifc IP addresses or protocols. Moreover, it has a robust set of multi-layer (L2, L3, L4) QoS/CoS features optimized for Triple-Play Services like Voice over IP (VoIP), Media-on-Demand (MOD), Intranet and video conferencing. Priority queues for 802.1p/TOS/DiffServ are supported, with classifcation and marking based on MAC SA/DA, IP SA/DA, and/or TCP/UDP port numbers.
D-Link DGS-3700 series provides a complete set of security features, which include IP-MAC-Port Binding (IMPB) with DHCP Snooping, L2/L3/L4 multi-layer Access Control Lists and 802.1X user authentication via TACACS+ and RADIUS servers. In addition, it also offers supression capabilities to enhance network performance and security. To prevent malicious fooding traffc caused by worm/virus infections, the DGS-3700 series in-built Safeguard Engine enforces its reliability, serviceability and availability.
OAM Management
To uphold enterprise customers’ SLA, service providers must reduce the Mean Time to Repair (MTTR) and increase service availability. Ethernet OAM features address these challenges and enable service providers to offer carrier-grade services. D-Link DGS-3700 series supports industry-standard OAM tools including IEEE 802.1ag Connectivity Fault Management and IEEE802.3ah Ethernet in the First Mile. IEEE 802.1ag protocol provide tools to monitor and troubleshoot end-to-end Ethernet networks allow service providers to check connectivity, isolate network issues, and identify customers affected by network issues. IEEE 802.3ah Ethernet in the First Mile protocol provides OAM discovery, local and remote loopback diagnostic on the link between the customers’ equipment and the service provider network.
מאפיינים כללים
Interfaces
• 8 SFP-ports
• 4-port Combo 10/100/1000BASE-T/SFP
• 1 console port, an RS-232
• 1 control port RJ-45
• 1 signaling RJ-45 port
Modular components
• Filter to remove dust
• Fan
• Power Supply AC / DC
Performance
• Switching matrix: 24Gbit / s
• Speed of packet forwarding: 17,86 Mpps
• Buffer packets: 1MB
• MAC Address Table: Up to 16K entries
• Size of Jumbo-frame: 13 312 bytes
Layer 2 features
• Virtual Stacking
• MAC-address table: 16K
• Flow control:
- Flow control 802.3h
- Prevent block HOL
• Size Jumbo-frames to 13 312 byte
• Spanning Tree:
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
- BPDU Filtering
- Root Restriction
• Loopback Detection Function
• Link Aggregation 802.3ad (LACP)
- Max. 6 groups per device / 8 Gigabit ports per group
• Port mirroring:
- One-to-One
- Many-to-One
- Flow-based mirroring
- Mirroring RSPAN *
• E-RPS (Ethernet Ring Protection Switching)
• Layer 2 Tunneling Protocol
Multicast Layer 2
• IGMP Snooping:
- IGMP v1/v2/v3 Snooping
- Support for IGMP groups do1K
- IGMP Snooping Fast Leave
- Host-Based IGMP Fast Leave
• IGMP / MLD Proxy Reporting
• Filtering IGMP / MLD
- Up to 60 profiles filtering IGMP, 128 ranges in profile
• MLD Snooping:
- MLD v1 Snooping
- MLD v2 Snooping *
- Supports up to 1K MLD snooping groups
- MLD Snooping Fast Leave
VLAN
• Group VLAN
- Max. number of groups static VLAN: 4K
- Max. number of groups of dynamic VLAN: 2K
• VLAN Trunking
• VLAN-based protocol 802.1v
• GVRP
• Double VLAN (Q-in-Q):
- Port-Based Q-in-Q
- Selective Q-in-Q
• Voice VLAN
• VLAN based on MAC addresses
• Guest VLAN
Quality of Service (QoS)
• Quality of Service (QoS) 802.1p
• 8 queues
• Cos on the basis of:
- Switch Port
- VLAN ID
- 802.1p Priority Queues
- MAC address
- Addresses IPv4/v6
- DSCP
- Type of protocol
- Class of traffic Iv6
- IPv6 flow labels
- TCP / UDP port
- The contents of the package, a user-defined
• 3-color marker
- TrTCM
- SrTCM
• Managing congestion:
- SRED
• Supports the following operations to streams:
- Change the 802.1p priority tag
- Change tag TOS / DSCP
- Bandwidth Management
- Statistics stream
- Committed Information Rate (CIR), in increments of 64 kbit / s
• Bandwidth Management:
- Based on the port (inbound / outbound minutes. Step 64Kb / s)
- Based on the flow (inbound / outbound minutes. Step 64Kb / s)
Access Control Lists (ACL)
• Up to 1500 access rules
• ACL based on:
- 802.1p priority queues
- VLAN ID
- MAC address
- Ether Type
- Addresses IPv4/v6
- DSCP
- Type of protocol
- Non TCP / UDP port
- Class of IPv6 traffic
- IPv6 flow labels
- The contents of the package, a user-defined (PCF)
• Time-Based ACL
• CPU Interface Filtering
• Statistics ACL
Security
• SSH v1/v2
• SSL v1/v2/v3
• Function Port Security: up to 128 MAC addresses per port / VLAN
• Office of Broadcast / много-адресным/одноадресным storm
• Traffic Segmentation
• The IP-MAC-Port Binding:
- Supports 500 entries per device
- Supports ARP / ACL / Auto (DHCP Snooping)
• Function D-Link Safeguard Engine
• Preventing ARP Spoofing
• DHCP Server Screening
• DHCP Client Filtering
• Protection against attacks BDPU
• Filtering NetBIOS / NetBEUI
AAA
• 802.1X:
- Access control based on port
- Access control based on hostname
- Dynamic VLAN Assignment
• Based Access Control Web (WAC):
- Access control based on a host *
• Access control based on MAC addresses (wt):
- Appointment of a dynamic VLAN
• Microsoft ® NAP (Support IPv4/v6)
• Authentication server via RADIUS and TACACS +
• Three levels of user authentication
• Maintain accounts via RADIUS
Performing Operations, Administration and Management (OAM)
• Loopback Diagnostic
• Cable Diagnostics
• Control connection errors 802.1ag (CFM)
- Support for 64 and 32 MIP MEP
• 802.3ah
• ITU-T Y.1731
• Optical Transceiver function Digital Diagnostic Monitoring (DDM)
Management
• Web-interface (Support IPv4/v6)
• Command Line Interface CLI
• Server Telnet (support IPv4/v6)
• Telnet-Client (support IPv4/v6) *
• TFTP-Client (support IPv4/v6)
• XModem
• ZModem
• SNMP v1/v2c/v3
• SNMP Traps
• System Log
• RMON v1
- Support groups 1,2,3,9
• RMON v2
- Support groups ProbeConfg
• SFlow
• LLDP
• LLDP-MED
• IPv6 Neighbor Discover (ND)
• BootP / DHCP-client
• DHCP automatically
• DHCP Relay Option 60
• DHCP Relay Option 61
• DHCP Relay Option 82
• DHCP-server
• DNS Relay
• DNS-client
• File System Flash (Flash File System)
• Support for two copies of the Software (Dual Image)
• Support for two copies of the configuration (Dual Confguration)
• Monitoring CPU
• Cable Diagnostics
• SNTP
D-Link Green
• RoHS Compliant 6
• Power saving mode
• Status disconnect the connection
MIB
• RFC1155, 2578 Structure of the MIB
• RFC1212 MIB definition
• RFC1213 MIBII
• RFC1493 Bridge MIB
• RFC1901 ~ 1908 SNMPv2 MIB
• RFC1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1643, 2358, 2665 Ether-like MIB
• RFC 2668 802.3 MAU MIB *
• RFC2674 Q-Bridge/P-Bridge MIB
• RFC2674 802.1p MIB
• RFC2233, 2863 IF MIB
• IGMPv3 MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC3298 MIB for Diffserv
• Ping MIB
• Traceroute MIB *
• Running Confguration MIB
• TFTP Update / Load MIB
• DDM MIB
• RFC2465 IPv6 MIB
• RFC2466 ICMPv6 MIB
• RFC4292 IP FDB MIB
• RFC4293 IPv6 SNMP Management Interface MIB
• D-Link Private MIB
Compliance with standards
• RFC768 UDP
• RFC791 IP
• RFC792 ICMPv4
• RFC2463 ICMPv6
• RFC4884 Extended ICMP
• RFC793 TCP
• RFC826 ARP
• RFC1981 Path MTU Discovery for IPv6
• RFC2460 IPv6
• RFC2461, 4861 IPv6 ND
• RFC2462 IPv6 Stateless Address
• Auto-configuration
• RFC2464 IPv6 over Ethernet and Definition
• RFC4291 IPv6 Address Architecture
• RFC4213 IPv4/IPv6 Dual Stack
• RFC2474, 3168, 3260 IPv6 Differentiated Services Field
