DGS-1005D/RUEOL EOS
מתג שולחני 5 פורטים 10/100/1000 (מארז פלסטיק)
תאור
Think green
The D-Link 5-Port Gigabit Switch is part of D-Link’s new series of SOHO devices that makes use of D-Link’s Green Technology,  roviding energy savings, reduced heat, and a longer product life without sacrificing operational performance or unctionality. An efficient power adapter (EnergyStar Level V qualified), minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
Conserves energy
The DGS-1005D 5-Port Gigabit Switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjusts power usage accordingly, helping you save energy without affecting networking performance.
Environmentally friendly
The 5-Port Gigabit Switch was designed with the environment in mind, and is compliant with Energy Star Level V, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
מאפיינים כללים
Protocol
• CSMA/CD
Data transfer rate
• Ethernet:
  - 10 Mbit/s (half duplex)
  - 20 Mbit/s (full duplex)
• Fast Ethernet:
  - 100 Mbit/s (half duplex)
  - 200 Mbit/s (full duplex)
• Gigabit Ethernet:
  - 2000 Mbit/s (full duplex)
Topology
• Star
Network Cables
• 10BASE-T:
  - UTP Cat. 3/4/5/5e (100m max.)
  - EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX, 1000BASE-T:
  - UTP Cat. 5/5e (100m max.)
Interfaces transfer medium
• Automatic detection of MDI/MDIX on all ports
Indicators
• The port:
  - Link / Activity / Speed
• On the device:
  - Power
Switching Method
• Store-and-forward
MAC-address table
• 4K entries per device
The study of MAC-address
• Automatic Update
Packet rate
• Ethernet: 14,880 packets per second at port
• Fast Ethernet: 148,800 packets per second at port
• Gigabit Ethernet: 1488000 packets per second at port
RAM Buffer
• 128 Kbytes per device
תקנים
הורדות
איורים
DGS-1005D/RU/F1
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
