מאפיינים כללים:
Interfaces
• 8-port 10/100BASE-TX PoE
Ports
• IEEE 802.3 10BASE-T Ethernet (copper wire twisted-pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper wire twisted-pair)
• Auto-negotiation ANSI/IEEE 802.3
• IEEE 802.3x Flow Control
Performance
• The capacity of the switch: 1.6 GB
• Maximum speed packet processor 64 bytes: 1.19 Mpps
• MAC-address table: 8K entries per device
• Buffer RAM: 384 KB
• SDRAM for CPU: 64 MB
• Flash-Memory: 16 MB
• Switching Method: Store-and-forward
Power over Ethernet (PoE)
• Standard PoE: 802.3af
• Functions of PoE ports
Ports 1-8 up to 15.4 Watt per port
• Power PoE: 72 Watt
Diagnostic Lights
• Power (per device)
• Link/Activity/Speed (per port)
Layer 2 features
• MAC Address Table: 8K
• Flow Control
802.3x Flow Control
HOL blocking prevention
• IGMP Snooping
IGMP v1/v2 Snooping
Supports up to 256 IGMP-group
Supports up to 64 static multicast groups
IGMP Snooping on the VLAN
Supports IGMP Querier
• Multicast filtering
Unregistered groups redirect
Unregistered groups filtering
• Spanning Tree Protocol
802.1D STP
802.1w RSTP
• Loopback detection
• Link aggregation 802.3ad
Max. number of groups per device - 8, 8 ports per group
• Port mirroring
One-to-One
Many-to-One
Flow based
• Cable diagnostics
• Customizable MDI/MDIX interface
VLAN
• 802.1Q tagged VLAN
• VLAN group
Max. 256 static VLAN
Max. 4094 VIDs
• Management VLAN
• Asymmetric VLAN
• Auto Voice VLAN
Max. 10 user defined OUI
Max. 8 by default defined OUI
• Auto Surveillance VLAN
Quality of service (QoS)
• 802.1p
• 4 queue
• Processing Queue
Strict
Weighted Round Robin (WRR)
• CoS-based
802.1p Priority Queues
DSCP
• Bandwidth Management
Based on the port (inbound/outbound, step up to 64 kbit/s for 10/100 Mbit/s and a step 1850 kbit/s to 1000 Mb/s)
Access Control Lists (ACL)
• Max. 50 member profiles
• Up to 240 incoming access rules
• ACL-based
MAC-address
IPv4-address
ICMP/IGMP/TCP/UDP
Security
• 802.1X
Access control based on port
• Port Security
Support for up to 64 MAC-addresses per port
• Control of Broadcast/Multicast/Unicast storm
• Static MAC-address
• D-Link Safeguard Engine
• DHCP Server Screening
• Preventing ARP Spoofing Attacks
Max. 64 records
• SSL
• Support v1/v2/v3
Management
• Web-GUI interface
• Compact CLI via Telnet
• Telnet-server
• Utility SmartConsole
• TFTP-client
• SNMP
Support v1/v2/v3
• SNMP Trap
• Trap for SmartConsole Utility
• Syslog
• Max. 500 entries in the log
• Supports IPv4 log serve
• BootP/DHCP-client
• Setting the time
SNTP
• LLDP1
• LLDP-MED2
• Time based PoE
MIB
• 1213 MIB II
• 1493 Bridge MIB
• 1907 SNMP v2 MIB
• 1215 Trap Convention MIB
• 2233 Interface Group MIB
• D-Link Private MIB
• Power Ethernet-MIB1
• LLDP-MIB1
Compliance with RFC
• RFC 768 UDP
• RFC 783 TFTP-client
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 854, 855, 856, 858 Telnet-server
• RFC 896 Congestion Control in TCP / IP Network
• RFC 903 Reverse Address Resolution Protocol
• RFC 951 BootP-client
• RFC 1155 MIB
• RFC 1157 SNMP v1
• RFC 1191 Path MTU Discovery
• RFC 1212 Concise MIB Definition
• RFC 1213 MIB II, IF MIB
• RFC 1215 Traps for use with the SNMP
• RFC 1239 Standard MIB
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1519 CIDR
• RFC 1942 BootP / DHCP client
• RFC 1901, 1907, 1908 SNMP
• RFC 1945 HTTP/1.0
• RFC 2131, 1232 DHCP
• RFC 2138 RADIUS Authentication
• RFC 2233 Interface MIB
• RFC 2570, SNMP 2575
• RFC 2578 Structure of Management Information Version 2 (SMIv2)
• RFC 2647 802.1p
• RFC 3416, SNMP 3417
• RFC 3621 Power Ethernet (only model PoE)
נתונים פיזיים
Dimensions
• Metal housing, 7.5''
MTBF (hours)
• 350,704 hours
Acoustics
• 0 dB
Heat release
• 305.03 BTU / hour
Power input
• External universal power supply from 100 to 240 VAC, 50/60 Hz
The maximum power consumption
• 89.4 Watt (PoE enabled)
• 9.7 Watt (PoE disabled)
Dimensions (W x D x H)
• 190 x 120 x 38 mm
Operating temperature
• From 0° to 40° C
Storage temperature
• -10° To 70° C
Operating humidity
• 5 to 95% (no condensation)
Electromagnetic compatibility
• FCC Class A, CE Class A, VCCI Class A, IC, C-Tick
Security
• cUL, CE LVD
