DEM-432XTEOL EOS
SFP 10GBASE-LR טראנסיבר (ללא DDM) לכבל singlemode (עד 10 ק"מ)
תאור
DEM-432XT is 10GBASE-LR SFP+ transceiver. 10GBASE SFP+ (Small Form-Factor Pluggable Plus) transceiver, which is targeted to support speed of 10Gbps, is an innovative, next-generation of 10GBASE transceiver. Compared with existing 10G XFP, 10G SFP+ is with smaller form factor, lower cost, lower power dissipation, and allows higher port density.
The D-Link 10GBASE SFP+ transceivers offer customers a wide variety of 10Gbps Ethernet connectivity option for data center, enterprise wiring closet, and service provider transport applications.
מאפיינים כללים
Functions
• Hot Plug
• MSA Compliant
• RoHS Compliant
Standards
• IEEE-802.3ae
• 10GBASE-LR
Transceiver type
• SFP +
Maximum cable length
• 10 km
Rate
• 10 Gb / s
Jack
• duplex LC
Wavelength
• 1310
Optical output power (TX)
• Max: +0.5 dBm
• Min.: -8.5 DBm
Optical input power (RX)
• Max.: +0.5 DBm
• Min.: -12.6 DBm
Sensitivity
• -12.6 dBm
Type of cable
• Single-mode fiber optic cable 9 / 125 micron
תקנים
הורדות
איורים
DEM-432XT
מראה מקדימה
דף מידע
ראה גם
