חיפוש מהיר
תכונות המוצר:
מתג שולחני 16 פורטים 10/100/1000 עם ספק כח מובנה (מארז מתכת)
דגם לא מיוצר יותר
מאפיינים כללים:
Main functions
• Innovative Technology 2nd Generation D-Link Green
• Inexpensive Gigabit solution for home and small office
• Quiet design with auto MDI / MDI-X on all ports
• Switching Method Store and Forward (store-and-forward)
• Full / half duplex for 10/100 Mbit / c
• IEEE 802.3x Flow Control
• Support for Jumbo Frames (9600 byte)
• Supports IEEE 802.1p QoS (4 queues, strict priority)
• Diagnosis of cable
• Compatibility with the directive ROHS
• Quick and Easy Installation (Plug-and-play)
Number of Ports
• 16 Gigabit ports
Switch fabric
• 32 Gb / s
Standards
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
• IEEE 802.3ab 1000BASE-T Gigabit
• Ethernet (twisted-pair copper)
• ANSI / IEEE 802.3 NWay auto-negotiation and speed of operation
• IEEE 802.1p QoS (4 queues, strict priority)
Protocol
• CSMA / CD
Data transfer rate
Ethernet:
• 10 Mbit / s (half duplex)
• 20 Mbit / s (full duplex)
Fast Ethernet:
• 100 Mbit / s (half duplex)
• 200 Mbit / s (full duplex)
Gigabit Ethernet:
• 2000 Mbit / s (full duplex)
Topology
• Star
Network Cables
• 10BASE-T:
  UTP category 3, 4, 5/5e (100 m)
  EIA/TIA-586 100-ohm STP (100 m)
• 100BASE-TX, 1000BASE-T:
  UTP Category 5/5e (100 m)
  EIA/TIA-568 100-ohm STP (100 m)
Data exchange interface
• Auto-detect MDI / MDI-X on all ports
Indicators
• Port: Link / activity / Speed
• Per device: Power
Switching Method
• Store-and-forward
MAC-address table
• 8K entries, Automatic Updates
Filtration rate / packet (half duplex)
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 packets per second per port
• Gigabit Ethernet: 1,488,000 packets per second per port
Volume of buffer memory
• 512 Kb on your device
נתונים פיזיים
Power consumption
• In standby mode: 3.8 W
• Maximum: 11.7 W
Heat release
• In standby mode: 12,96 BTU / hr
• Maximum: 39,9 BTU / hr
Noise level
• 0 dB
MTBF
• 828.109 hours
Operating temperature
• From 0 to 40 ˚ C
Storage temperature
• -10 To 70 ˚ C
Operating humidity
• From 10% to 90% noncondensing
Storage humidity
• From 5% to 90% noncondensing
Dimensions
• 280 x 180 x 44 mm
Weight
• 1.352 kg
Certificates
• FCC Class A
• ICES-003 Class A
• CE Class A
• C-Tick Class A
• VCCI Class A
• cUL
• CB
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
