חיפוש מהיר
תכונות המוצר:
מתג מנוהל 24 פורטים SFP+, עם מודול הרחבה, עם ספק כח ושלושה מאווררים
מאפיינים כללים:
Interface
• 24 fixed 10 Gigabit Ethernet ports with one expansion module
Console port
• RJ-45 to control the out-of-band
Port management
• 10/100/1000 Base-T with RJ-45 connector for remote control of out-of-band
Slot for SD-Card
• 1
Performance
• Switching Matrix: 960 Gbit / s
• Max. packet rate: 595.2 Mpps
• Size of the packet buffer size: 9 MB
• MAC-address table: 128K
Software
Stacking
• Virtual Stacking / up to 32 devices in steke2
  - Support for D-Link Single IP Management
L2 functions
• MAC-address table
  - 128K records
• Flow Control
  - 802.3x Flow Control in full duplex mode
  - Method of Back Pressure for half duplex
  - HOL Blocking Prevention
• Spanning Tree
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - Root Restriction
• The Loopback Diagnostics2
• 802.1AX Link Aggregation
  - Max. 16 groups per device, 12 ports per group
• ERPS2 (Ethernet Ring Protection Switching)
• Port Mirroring
  - One-to-One, Many-to-One
  - Supports Mirroring for Tx / Rx / Both
  - Up to 4 groups
• Flow Mirroring
  - Rx
   - Up to 4 groups
• Jumbo-size frames
  - Up to 12,000 bytes
Multicast Layer 2
• IGMP Snooping
  - IGMP v1/v2/v3 Snooping
  - Supports 4K IGMP groups
  - Supports up to 1K static multicast groups
  - IGMP on a VLAN
• Filtering of multicast
  - Redirect all groups
  - Redirect all non-registered groups
  - Filtering of unregistered groups
• MLD Snooping2
  - MLD v1/v2 Snooping
  - Supports up to 4K groups
  - MLD Snooping Fast Leave on the basis of host
VLAN
• 802.1Q
• 802.1v
• The Double VLAN (Q-in-Q)
  - Q-in-Q port-based
  - Selective Q-in-Q
• VLAN-based port
• VLAN MAC-based address
• VLAN-based subnets
• Private VLAN2
• Group VLAN
  - Max. 4K static VLAN groups
  - Max. 4094 VIDs
• GVRP
  - Up to 4K dynamic VLAN groups
QoS (Quality of Service)
• 802.1p
• 8 queues per port
• Queue management
  - Strict
  - Weighted Round Robin (WRR)
  - Strict + WRR
  - Round Robin (RR)
  - Weighted Elastic Round Robin (WERR)
• CoS-based
  - 802.1p Priority Queues
  - DSCP
  - IP-address
  - MAC-address
  - VLAN
  - IPv6-Class Traffic
  - IPv6 flow labels
  - TCP / UDP port
• Bandwidth Management
  - Based on the port (Outbound / Inbound / min. Step up to the 8 kbit / s)
  - Based on the flow (incoming / outgoing / min. Step up to the 8 kbit / s)
  - The output queue (at least step up to the 8 kbit / s)
• Three Color Marker
  - TrTCM
  - SrTCM
• Congestion Control
  - WRED
• Supported actions with the flow:
  - Tagging 802.1p priority
  - Adding a tag TOS / DSCP
  - Flow Control
  - Committed Information Rate (CIR)
L3 functions
• ARP
  - 512 Static ARP
  - Gratuitous ARP2
• IP-Interface
  - Supports up to 256 interfaces
• Loopback Interface 2
• VRRP
• IPv6 Tunneling2
  - Static
  - ISATAP
  - GRE
  - 6to4
Layer 3 routing
• Default Routing
• Static Routing
  - Max. up to 1K entries for IPv4
  - Max. up to 512 entries to IPv62
  - Support for the distribution of routes
  - Support for the secondary route
  - Support for equal / weighted cost multipath routing
• Supports up to 16K entries for IPv4/IPv6 routing
  - Max. 16K IPv4 records
  - Max. 8K IPv6 records
• Supports 8K L3 shared items sent to IPv4/IPv6
  - Max. 8K IPv4 records
  - Max. 4K IPv6 records
• RIP
  - RIP v1/v2
  - RIPng2
• OSPF
  - OSPF v2
  - OSPF v32
  - OSPF Passive Interface
  - Stub / NSSA Area
  - OSPF Equal Cost Route
• BGPv4
• Redistribution of routes
• IP Directed Broadcast
• Policy-based routing
Multicast Layer 3
• The size of the multicast table: 2K
• IGMP v1, v2, v3
• PIM-SM
• PIM-DM
• PIM-Sparse-Dense Mode
• PIM-SSM
• DVMRP v3
• MLD v1/v2
MPLS2
• LDP
• MPLS LSP trigger filtering
• MPLS label-forwarding
• MPLS QoS
• MPLS ping and traceroute
• L2 protocol tunneling through PW
• VPWS
• VPLS
• PW Redundancy
L3 VPN2
• MPLS / BGP L3 VPN
• VRF-Lite
• MP-BGP
• VRF aware application
Access Control Lists (ACL)
• Max. ACL entries:
  - Up to 1792 incoming access rules
  - Up to 1K outgoing access rules
  - Up to 1K rules VLAN
• ACL-based time
• ACL based on:
  - 802.1p Priority
  - VLAN
  - MAC-address
  - Ether type
  - IP-address
  - DSCP
  - Type of protocol
  - Non TCP / UDP port
  - Class of IPv6 traffic
  - IPv6 flow labels
Security
• Port Security
  - Up to 12K MAC-addresses on the port / system
• Control of Broadcast / много-адресных/одноадресных storms
• D-Link Safeguard Engine2
• DHCP Server Screening2
• The IP-MAC-Port Binding2
  - Checking the ARP-packets
  - Verification of IP-packets
  - DHCP Snooping
• Prevent attacks ARP Spoofing2
  - Max. 64 records
• Segmentation of Traffic
• SSL2
  - Support v1/v2/v3
  - Support for access IPv4/v6
• SSH
• Prevent attacks BPDU
• DOS Attack Prevention
AAA
• 802.1X
  - Access control based on port
  - Access control based on the host
  - Dynamic VLAN Assignment
  - Identity-driven Policy (VLAN / ACL / QoS) Assignment
• Access web-based interface (WAC) 2
• Access control based on MAC-address (MAC) 2
• Guest VLAN
Standard MIB and RFC
• RFC1213 MIB II
• RFC1907 SNMP v2 MIB
• RFC5519 IGMP v3 MIB
• RFC1724 RIP v2 MIB
• RFC2021 RMONv2 MIB
• RFC1643, RFC2358, RFC2665 Ether-like MIB
• RFC2668 802.3 MAU MIB
• RFC2674 802.1p MIB
• RFC2096 IP Forwarding Table MIB
• RFC2932 IPv4 Multicast Routing MIB
• RFC2934 PIM MIB for IPv4
• RFC2925 Trace Out MIB
• RFC2925 Ping MIB
• RFC1850 OSPF MIB
• Private MIB
• RFC1112, RFC2236, RFC3376, RFC4541 IGMP Snooping
• RFC4363 802.1v
• RFC2338 VRRP
• RFC1058, RFC1388, RFC1723, RFC2453, RFC2080 RIP
• RFC1370, RFC1765, RFC2328, RFC2740, RFC3101 makes RFC1587 obsolete, RFC2328 makes RFC1583, RFC2178 OSPF v2, v3
• RFC1771, RFC1997, RFC2439, RFC2796, RFC2842, RFC2918 BGP
• RFC3973 PIM-DM
• RFC5059 PIM-SM
• RFC3569, RFC4601, RFC4608, RFC4607, RFC4604 PIM SSM
• RFC3376 IGMP
• RFC2475 Priority Queue Mapping
• RFC2475, RFC2598 Class of Service (CoS)
• RFC2597, RFC2598 QoS Flow Actions
• RFC2697, RFC2698 Three Color Marker
• RFC2093, RFC2904, RFC2095, RFC2906 AAA
• RFC1321, RFC2144, RFC2313, RFC2420, RFC2841, RFC3394 Encryption
• RFC2289 One-Time
• RFC3580 802.1X
• RFC2866 RADIUS Accounting
• RFC2138, RFC2139, RFC2865, RFC2618 RADIUS Author. for Management Access
• RFC1492 TACACS + Auth. for Management Access
• RFC2068, RFC2616 Web-based GUI
• RFC854 Telnet Server
• RFC783, RFC1350 TFTP Client
• RFC1157, RFC1901, RFC1908, RFC2570, RFC2574, RFC2575, RFC3411-SNMP 17
• RFC3164 System Log
• RFC2819 RMON v1
• RFC951, RFC1542, RFC2131, RFC3046 BootP / DHCP Client
• RFC1769 Time Setting
• RFC2131 DHCP Server
• RFC1191 MTU Setting
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 MIB Structure
• RFC4188 Bridge MIB
• RFC1157, RFC2571-2576, RFC3411-3415, RFC3418 SNMP MIB
• RFC1901-1908, RFC1442, FC2578 SNMP v2 MIB
• RFC2737 Entity MIB
• RFC768 UDP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC1338, RFC1519 CIDR
• RFC2716, RFC3748 EAP
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
Management
• Management of web-based interface
• Command Line Interface CLI
• Telnet Server
• The TFTP client
• FTP Client
• Monitoring of
• SNMP
  - Support v1/v2/v3
• SNMP Trap
• System log
• DHCP - client
• DHCP-server
• DHCP Relay
• Support for multiple versions of software
• Support for multiple versions of configurations
• Flash File System
• DNS Resolver
• CPU Monitoring
• MTU Setting
• Traceroute
• LLDP
• DNS Relay
• SMTP2
• Automatic DHCP2
• SNTP
• RCP2
• RMONv1
• RMONv2
• Trusted host (Trusted Host) 2
• Password Encryption
• Command debug (Debug Command)
נתונים פיזיים
Input Power
• 100-240 VAC, 50/60 Hz
Power consumption
• Max.: 115.3 watts (without expansion module)
• Standby mode: 85.9 Tues
Heat release
• Max.: 393.4 BTU / h
• Stand: 293.1 BTU / h
Dimensions (W x D x H)
• 440 x 506 x 44 mm
Operating temperature
• From 0 to 45 ° C
Storage temperature
• From 40 to 70 ° C
Operating humidity
• From 0% to 95%
Storage humidity
• From 0% to 95%
Diagnostic Lights
• Per device: Power 1, Power 2, Fan 1, Fan 2, Fan 3, Console, MGMT, SD Card, Stacking ID
• The SFP + port: Link / Activity / Speed
Certificates
• Safety: CB, cUL, LVD
• EMI / EMC: FCC, CE, C-Tick, IC, VCCI
2 These functions will be supported in future versions of the software
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
