חיפוש מהיר
תכונות המוצר:
מתג שולחני עם 8 פורטים 10/100/1000 עם חסכון בחשמל (מארז פלסטיק)
תאור:
The implementation of technology D-Link Green
8-Port Gigabit Switch DGS-1008A is part of a new series of devices for SOHO from company D-Link, which use a technology called D-Link Green, which provides energy conservation, lower heat and longer product life without sacrificing performance or functionality. Energy-saving power adapter (certified standard Energy Star Level V), to minimize the use of hazardous substances (compliance directive RoHS) and recyclable packaging provides environmental friendliness of this switch.
Conservation of energy
8-Port Gigabit Switch DGS-1008A provides automatic saving of electricity in several ways. With the automatic power off when there is no connection ports are saving a significant amount of energy on the inactive port or ports that are connected to the computer is off.
Protecting the environment
8-Port Gigabit Switch DGS-1008A is designed taking into account the factor of protection of the environment and complies with Energy Star Level V, as well as compulsory regulations CEC and MEPS, which prescribe the use of energy-efficient power adapters. Also, the switch is designed in accordance with RoHS standards to minimize the use of hazardous materials and uses recycled packaging to help reduce waste by following the requirements of the directive WEEE.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
