DGS-1008D/H1EOL EOS
8-Port Gigabit Switch
תאור
Think Green
The D-link 8-Port Gigabit Switch is part of D-Link’s new series of SOHO devices that makes use of D-Link’s Green Technology, providing energy savings, reduced heat, and a longer product life without sacrificing operational performance or functionality. An efficient power adapter (Energy Star Level V qualified), minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
Conserves Energy
The DGS-1008D 8-Port Gigabit Switch helps you conserve energy automatically through several methods. It features the IEEE802.3az EEE (Energy Efficient Ethernet) standard which reduces energy consumption by transitioning into a low-power state during periods of minimal usage without interrupting your network. The DGS-1008D will also automatically power down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjusts power usage accordingly, helping you save energy without affecting networking performance.
Environmentally Friendly
The 8-Port Gigabit Switch was designed with the environment in mind, and is compliant with Energy Star Level V, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
מאפיינים כללים
Key features
• Built-in D-Link Green Technology
• Inexpensive Gigabit solution for Home/SOHO
• Eight 10/100/1000Mbps Gigabit ports
• 16Gbps switching fabric
• Auto MDI/MDIX crossover for all ports
• Secure store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Supports 9,720 Byte Jumbo Frames
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Supports Cable Diagnostics Function
• RoHS compliant
• Plug-and-play installation
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3az EEE compliant
• IEEE 802.1p QoS
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Gigabit Ethernet:
• 2000Mbps (full duplex)
Topology
• Star
Network cables
10BASE-T:
• UTP CAT 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX, 1000BASE-T:
• UTP CAT 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
LED indicators
• 8 Status LEDs (one per port)
Transmission method
• Store-and-forward
MAC address table
• 4K entries per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
• Gigabit Ethernet: 1,488,000pps per port
RAM buffer
• 192Kbytes per device
תקנים
הורדות
DGS-1008D/H1 8-Port Gigabit Switch
