חיפוש מהיר
תכונות המוצר:
מתג שולחני עם 16 פורטים במהירות 10/100Mbps ועם תכונת חיסכון בחשמל (מארז מתכת)
תאור:
The ideal solution for basic network problems
With the switch D-Link DES-1016D and DES-1024D can easily expand the network by adding a set of computers or devices at speeds of 200 Mbit / s full duplex.
Automatic detection port 10/100 Mbit / s
DES-1016D DES-1024D and use auto-detection feature-port 10/100 Mbit / s, allowing small workgroups can easily connect to devices with 10 or 100 Mbit / s to create an integrated network. Each port automatically adjusts for straight-through or crossover
cable for proper connection.
Flow control for secure transmission
All ports support flow control, 802.3x. This function prevents packet loss through transmission of a possible buffer overflow.
Quality of Service (QoS)
The switches support priority queues 802.1P, allowing users to use the network latency-sensitive applications such as multimedia and Internet telephony (VoIP).
Reduction in energy costs
Switches conform IEEE802.3az EEE, consuming less power with a small amount of traffic. This reduces energy costs.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
