DES-1008D/J2EOL EOS
8-Port 10/100 Switch
תאור
Auto-sensing 10/100 ports
The DES-1008D 8-port 10/100Mbps switch uses auto-sensing 10/100Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-T and 100BASE-TX, as well as between full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX Crossover
All of the ports on the DES-1008D support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
When a port reaches its receiving buffer capacity, the 802.3x flow control feature activates to minimize dropped packets. By minimizing the number of dropped packets, the switch provides a more reliable connection for all of your connected devices while surfing the web, playing games, or accessing media.
מאפיינים כללים
Key features
• Inexpensive Fast Ethernet solution for Home/SOHO
• Eight 10/100Mbps Fast Ethernet ports
• Auto MDI/MDIX crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Plug-and-play installation
• RoHS compliant
Switching fabric
• 1.6Gbps
Standards
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x flow control
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Topology
• Star
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
Network cables
10BASE-T:
• UTP CAT 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX:
• UTP CAT 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
LED indicators
• Per port: Link/Activity
• Per device: Power
Transmission method
• Store-and-forward
MAC address table
• 2K per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
תקנים
הורדות
DES-1008D/J2  8-Port 10/100 Switch
איורים
DES-1008D/J2J
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
