חיפוש מהיר
תכונות המוצר:
מתג שולחני עם 8 פורטים במהירות 10/100Mbps (מארז פלסטיק)
תאור:
The switch DES-1008A 8-port 10/100 Mbit / s allows you to quickly create a wired network . Connect the DES-1008A to multiple computers to share the files and folders , or connect it to a router to share an Internet connection.
High Speed ​​Networking
The switch DES-1008A is equipped with a port 10 /100 Mbit / s auto- negotiation , allowing a small workgroup to connect to devices with Ethernet and Fast Ethernet devices to create an integrated network. These ports determine the speed of the network and perform auto-negotiation between 10BASE-T and 100BASE-TX, as well as between modes of half-and full -duplex to provide each network device to the maximum possible speed.
Automatic determination of the polarity of MDI / MDIX
All ports DES-1008A support automatic polarity of MDI / MDIX, which eliminates the need for cross over cables or uplink ports and can be directly connected to each port on a server , hub , router, or switch using standard Ethernet- cable straight -through twisted- pair.
Flow control
All ports support flow control 802.3x. This feature allows you to prevent the loss of packets by transmitting a signal of a possible buffer overflow . Through the reduction of lost packets , the switch provides a more reliable connection for all connected devices while web- surfing , online games or access multimedia portals .
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
