DGS-3620-28PCEOL
תאור
The switches of the new generation series xStack DGS-3620 provides networks of large enterprises and small and medium-sized business (SMB) high performance, flexibility, security, multi-layer Quality of Service (QoS) and the ability to connect a backup power source. The switches provide high-density Gigabit Ethernet ports for connecting workstations, equipped with SFP ports and 10 Gigabit SFP + and supports the advanced features of the software. The switches can be used as a device-level access units or in the core of the network to create a multi-level network structure with high-speed backbone and centralized servers connection. Service providers can also take advantage of the switch to the high-density SFP ports to form the core optical network (FTTB).
Virtual Stack
Built-in Single IP Management technology allows the switch DGS-3620 to become part of a virtual stack and create a multi-level network structure with high-speed backbone and centralized servers connection. Are combined to a stack unit placed in any point of the same network domain, and the additional ports 10-Gigabit uplink for transmitting traffic vnutristekovogo at 20 Gbit / s in full-duplex mode. This will minimize the impact of single point of failure, avoiding the problems associated with long cables and physical stacking method, and eliminates the need for cables for stacking.
Stacking on the topology of the "ring"
Alternatively, a virtual stack, depending on the topology stacking - a linear or fault-tolerant "ring", users can use one or two ports of 10 Gigabit Ethernet SFP +, to create a physical stack. In such a stack, you can combine up to 12 series switches DGS-3620 to get up to 576 ports of Gigabit Ethernet. This enables not only high capacity stack, but the ability to control costs.
Safety, performance and availability Switches DGS-3620 series provides a complete set of security features, including multi-level L2 / L3 / L4 Access Control Lists and 802.1x user authentication via TACACS + and RADIUS.
Built-in ZoneDefense a mechanism to co-operate switches D-Link xStack series and firewalls and provides proactive network security.
To improve the performance and safety switches series DGS-3620 provides extensive support for VLAN, including GVRP and 802.1Q. To support converged applications including VoIP, ERP, and videoconferencing, rich feature set QoS / CoS 2/3/4 levels ensures that critical network services are served with proper priority. To protect the switches against traffic flooding caused by virus / worm series switches DGS-3620 provides a feature D-Link Safeguard Engine, providing safety, reliability and network availability. Bandwidth control in steps of 64 kbit / s allows you to limit the bandwidth for each port. Bandwidth control for each flow allows tuning of service types based on specific IP-addresses or protocols.
Support for IPv6
Series Switches DGS-3620 supports IPv6, including IPv6 Tunnel, ICMPv6, DHCPv6, RIPng, OSPFv3, BGP +, and so on. D. Due to port 10-Gigabit and IPv6 support series DGS-3620 is a cost effective solution that is compliant with IPv6 in accordance with the demands in the future.
Technology D-Link Green
D-Link is a leader in the development of innovative energy-saving technology that does not sacrifice performance or functionality. Switches DGS-3620 series support the technology D-Link Green, which allows the use of power-saving mode, Smart Fan, reduce heat, and automatically reduce power consumption based on cable length. The power saving feature automatically powers down ports. Smart Fan function automatically turns on the built-in fans at a certain temperature, providing continuous, reliable and eco-friendly operation of the switch.
מאפיינים כללים
General
• Interface
o 20 ports of 10/100 / 1000BASE-T
o 4 combo 10/100 / 1000BASE-T / SFP
o 4 SFP +
• Redundant Power Supply: DPS-700
• Console port: RJ-45
• Managing port 10 / 100BASE-T
• 1 alarm port
• 1 slot for SD-cards
Performance
• Switching Matrix: 128 Gbit / s
• The speed of packet forwarding: 95,24 Mpps
• Buffer packages: 2MB
• MAC-address table 32 K entries
• Routing Table: IP v4 / v6
• Switching table L3 IPv4: 8 K entries
• Switching table L3 IPv6: 4 K entries
• Jumbo Frame: 13 KB
PoE
• Standard PoE: 802.3af and 802.3at
• Budget Power PoE: 370 W (740 W redundant power supply DPS-700)
Features stacking
• Supports Virtual Stacking
o D-Link Single IP Management
o Up to 32 devices connected to the virtual stack
o bandwidth of up to 20 GB
• Physical Stacking
o The technology stack supports the "circuit" and "ring"
o The bandwidth of up to 40 GB
o Up to 12 devices on the stack
Features 2 levels
• MAC-address table: 32K
• Flow Control
o 802.3x Flow Control
o HOL Blocking Prevention
• packet size Jumbo Frame: up to 13 K bytes
• IGMP snooping
• IGMP v1 / v2 / v3 Snooping
o IGMP v1 / v2 / v3 Snooping
o Supports up to 1K IGMP Snooping groups
o IGMP Fast Leave port-based / host
• MLD Snooping
o MLD v1 Snooping
o Supports up to 1K MLD snooping groups
o MLD Snooping Fast Leave-based hosts
• Spanning Tree
o 802.1D-2004 STP
o 802.1w RSTP
o 802.1Q-2005 MSTP
o Filtering BPDU
o Root restriction
• Loopback Detection
• 802.3ad Link Aggregation
• A maximum of 32 groups on the device
o 8-port Gigabit or 2 ports of 10G device
• Port mirroring:
o Support 4 groups mirroring
Mode o One-to-One
o Mode Many-to-One
o Flow-based Mirroring
o RSPAN
• L2 Protocol Tunneling
VLAN
• VLAN Group
• The maximum number of static groups VLAN - 4K
• The maximum number of dynamic groups VLAN - 255
• 802.1Q Tagged VLAN
• 802.1v Protocol VLAN
• GVRP
• Double VLAN (Q-in-Q)
o Port-based Q-in-Q
o Selective Q-in-Q
• MAC-based VLAN
• VLAN Trunking
• Super VLAN
Features 3 levels
• Number of IP-interface: 256
• Loopback interface
• VRRP
• IPv6 Ready Phase 2
• Proxy ARP
• Gratuitous ARP
Routing Level 3
• Up to 12 devices to record routing protocols using IPv4 / v6
o Up to 12K IPv4 routes
o Up to 6K IPv6 routes
• Up to 8K records of all devices sent protocols IPv4 / v6
o Up to 8K entries for IPv4
o Up to 4K entries for IPv6
• Up to 256 entries for the static routing IPv4, up to 128 entries for IPv6
o Support ECMP / WCMP
• Policy-based routing
• RIP v1 / v2
• OSPF
o OSPF v2
o OSPF Passive Interface
o Stub / NSSA Area
o OSFP Equal Cost Route
Multicasting
• Up to 2K groups
• PIM-DM
• PIM-SM
• The PIM Sparse-Dense
• IGMP v1 / v2 / v3
QoS (Quality of Service)
• 802.1p Class of Service (CoS)
• 8 queues
• Processing Queue
o Strict Mode
o mode Weighted Round Robin (WRR)
o Strict + WRR mode
• CoS-based
o Port Switch
o VLAN ID
o 802.1p priority queues
o MAC-e
o IPv4 / v6-address
o DSCP
o The type of protocol
o IPv6 traffic class
o IPv6 flow label
o Non portaTCP / UDP
o contents of the package, user-defined
• Support for the following streams
o Tag 802.1p priority
o Label TOS / DSCP
o Bandwidth Management
o Statistics stream
o Guaranteed average information rate (CIR) at least 1 kbit / s
• Bandwidth Management
o Based on the port (Ingress / Egress, minimum - 64 kbit / s)
o Based on the flow (Ingress / Egress, at least - 64 kbit / s)
• Time-based QoS
ACL (Access Control Lists)
• Ingress ACL: support up to 6 256 profiles and policy profile
• Egress ACL: support for up to 4 profiles and 128 policy profile
• ACL based
o VLAN ID
o MAC-addresses
o Ether Type
o IPv4 / v6-e
o DSCP
o Non-TCP / UDP port
o Class trafikaIPv6
o IPv6 flow label
• ACL statistics
• Time-based ACL
• CPU interface fltering
Security
• SSHv2
• SSL v1 / v2 / v3
• The Port Security (MAC-64 addresses per port)
• Management of broadcast / multicast / unicast storm
• Traffic Segmentation
• The IP-MAC-Port Binding
o Checking the ARP-packets
o Checking the IP-packet
o DHCP Snooping
o DHCPv6 and NDP Snooping
o Up to 500 entries per device
• D-Link Safeguard Engine
• DHCP Server Screening
• CPU Interface Filtering
• Prevention of ARP Spoofing Attacks
• Protection against attacks BDPU
AAA
• 802.1X
o Based Access Control ports
o Based Access Control hosts
o Dynamic VLAN assignment
• Access control based on Web (WAC)
o Access Control based on port
• Access Control MAC-based (MAC)
• Japan-based access control WEB-interface
• Microsoft NAP
o Support for 802.1X NAP
o Support for DHCP NAP
• Guest VLAN
• Authentication to access the switch RADIUS and TACACS +
• Accounts with 4 levels of privilege
DDM (Digital Diagnostics Monitoring)
Yes
Management
• Web-interface
• Command Line Interface (CLI)
• ServerTelnet
• Telnet Client
• TFTP-client
• ZModem
• SNMP v1 / v2c / v3
• SNMP Trap
• System Log
• RMON v1
o Support groups 1,2,3,9
• RMON v2
o Support ProbeConfig
• sFlow
• LLDP / LLDP-MED
• BootP / DHCP-Client
• Auto DHCP
• DHCP Relay
• DHCP Relay Option 60; 61
• DHCP Relay Option 82
• DHCP-server
• Flash File System
• Support for multiple copies of the Software (Multiple Images)
• Support for multiple copies of configurations (Multiple Configurations)
• Monitoring the CPU usage
• Use the debug
• SNTP
• ICMPv6
• DHCPv6 Client
• DHCPv6 Relay
• DHCPv6 Server
• Trusted host
• Configuring MTU
• Microsoft® NLB Support
• UDP helper
OAM
• 802.3ah Ethernet Link OAM
• 802.3ah D-Link Extension: D-Link
Unidirectional Link Detection (DULD)
• IEEE1588 Precision Time Protocol (PTP)
Standard MIB / IETF
• RFC1213 MIB-II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC2571 ~ 2576 SNMP MIB
• RFC1271, 2819 RMON MIB
• RFC2021 RMON v2 MIB
• RFC2665 Ether-like MIB
• RFC2668 MAU MIB
• RFC2674 802.1p MIB
• RFC2233, 2863 IF MIB
• RFC1724 RIP v2 MIB
• RFC1850 OSPF v2 MIB
• RFC2096 IP Forwarding Table MIB (CIDR)
• RFC2787 VRRP MIB
• RFC2932 IPv4 Multicast Routing MIB
• RFC2934 PIM MIB for IPv4
• RFC2933 IGMP MIB
• Ping MIB
• Traceroute MIB
• D-Link Private MIB
• RFC768 UDP
• RFC783 TFTP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC854 Telnet
• RFC951, 1542 BootP
• RFC2068 HTTP
• RFC2338 VRRP
• RFC2529, 3053, 3056 IPv6 Tunnel
• RFC2138 RADIUS
• RFC2139 RADIUS Accounting
• RFC1492 TACACS
• RFC3176 sFlow
• RFC2598 DiffServ Expedited Forwarding
• RFC2460 IPv6
• RFC4861 IPv6 Neighbor Discovery (ND)
• RFC4862 IPv6 Stateless Address Autoconfguration
• RFC1981 IPv6 Path MTU Discovery
VLAN
• 802.1Qbb
Function level 3
• IPv6 Tunneling
o Static
o ISATAP
o GRE
o 6to4
Routing Level 3
• RIPng (IPv6)
• OSPF
o OSPF v3 (IPv6)
• BGP v4
o BGP + v4
Multicasting
• PIM-SM v6
• DVMRP v3
OAM
• Diagnosis cable
• 802.1ag Connectivity Fault
Management (CFM)
• ITU-T Y.1731v3
MPLS
• VRF
• Label Management
• LDP
• MPLS L3 VPN (MPLS / BGP VPN)
• MPLS L2 VPN
• VPLS
