DES-1016DEOL EOS
תאור
Main Features
16 x NWay 10/100BASE-TX Fast Ethernet Ports
Full and half duplex support for each port
All ports support auto-negotiation function
Desktop sized, Saving space
Supplied with 19"
rack-mount kit
Product description
The DES-1016D is an unmanaged 10/100Mbps switch designed to enhance workgroup performance while providing a high level of flexibility. Powerful yet easy to use, this device allows users to simply plug any port to either a 10Mbps or 100Mbps network to multiply bandwidths, boost response time and satisfy heavy load demands.
16 Auto-sensing 10/100Mbps Ports
The switch comes with 16 10/100Mbps ports, allowing a small workgroup to flexibly integrate to Ethernet and Fast Ethernet. These intelligent ports detect the network speed and auto-negotiate between 100BASE-TX and 10BASE-T, as well as between full and half-duplex.
Flow Control for Secure Transmission
All ports support flow control. This function minimizes dropped packets by sending out collision signals when the port's receiving buffer is full.
MDI/MDIX Cross Over
All ports support auto-negotiation of MDI/MDIX cross over. This eliminates the need for cross over cables or uplink ports. Any port can simply plug to a server, a hub or a switch, using the usual straight-through twisted-pair cable.
Plug-and-Play
With 16 plug-and-play ports, the switch is a perfect choice for workgroups to upgrade performance in a client/server environment. The ports can be connected to servers in fullduplex, or hubs in half-duplex.
Direct Connection to Workstations
With low-cost connection per-port, the switch can be set up for direct connection from the PCs. This relieves data bottleneck by giving each workstation a dedicated bandwidth on the network.
מאפיינים כללים
| Technical Specifications | |||||||||||
Standards |
Features |
Network Data Transfer Rate |
Interface Options |
Certifications |
Led |
Power Consumption |
Power Supply |
Operating Temperature |
Humidity |
Dimensions |
Weight |
Warranty |
Minimum System Requirements |
Package Contents |
