Interface |
10/100BASE-TX Ports |
Combo 10/100/1000BASE-T Ports/SFP Slots |
Auto-Negotiation of Network Speeds (RJ-45 Ports) |
Auto-MDI/MDIX (RJ-45 Ports) |
RS-232 Console Port |
Power |
Internal Power Suply |
Power Input |
100 to 240VAC, 10A, 50 to 60Hz | |
Power Output |
Power Consumption |
Optional Redundant Power Supply |
Performance |
Switching Capacity |
Maximum 64-Byte System Packet Forwarding Rate |
MAC Address Table |
Packet Buffer Size |
Diagnostic LEDs |
10Mbps or 100Mbps Speed (Per Ethernet Port) |
10/100Mbps or 1000Mbps Speed (Per Gigabit Port) |
Link/Activity (Per Port) |
Power, Console, RPS (Per Device) |
Physical & Environmental |
Ventillation DC Fans |
BTU/Hour |
Dimensions (W x D x H) |
17.4” x 12.2” x 1.7” (441mm x 309mm x 44mm) | |
Size |
19-inch Standard Rack-Mount Width, 1U Height | |
Weight |
Temperature |
Operating: 32° to 104°F (0° to 40°C) |
Storage: -40° to 158° F (-40° to 70° C) | |
Humidity |
5% ~ 95% Non-condensing | |
EMI |
FCC Class A, CE, C-Tick | |
Safety |
MTBF |
Acoustic (Refer to ISO-7779) |
Software Functions |
VLAN |
IEEE 802.1Q Tagged VLAN |
Port-based VLAN |
Maximum Number of VLANs per Device: 255 VLANs (Static and Dynamic Combined) |
GARP/GVRP | |
Priority Queues (CoS) |
Standard: IEEE 802.1p |
Number of Queues: 4 | |
Traffic Classification (Cos) Can be used on user-definable application types: |
TOS |
Diffserv (DSCP) |
Port-based |
MAC Address |
IP Address |
TCP/UDP Port Number | |
Security |
Port Security (64 MAC Addresses Maximum) |
802.1x Port-based Access Control |
802.1x MAC-based Access Control |
SSH v1, v2 |
SSL v2 |
Per Port Traffic Segmentation |
IP-MAC-port Binding (512 Entries) |
DHCP Client Filtering |
DHCP Server Screen |
NetBIOS Filtering |
TACACS |
RADIUS Authentication for Management | |
Access Control List Multi-layer ACL (100 entries) based on: |
Port Number |
TOS |
Diffserv (DSCP) |
MAC Address |
IP Address |
Packet Prototcol Type |
TCP/UDP Port Number (User-definable Application Types) |
TCP/UDP Payload (User-definable Packet Content) |
Per Port ACL Definition | |
Spanning Tree Protocol |
802.1D Spanning Tree Compatible (802.1D, 2004) |
802.1w Rapid Spanning Tree (Ring Protection with Network Recovery Time of Less Than 15 Seconds) |
Per Port BPDU Filter | |
IP Multicast |
IGMP v1, v2 |
IGMP Snooping (128 Groups) |
Enable Definite VLAN for Multicast |
IGMP Fast Leave |
User-definable Per-port IP Multicast Range Limit | |
Port Trunk |
Maximum Number of Ports per Trunk: 8 |
Maximum Number of Trunks per Device: 6 |
Operation Mode: Load Sharing |
802.3ad compatible Link Aggregation (LACP) Static and Dynamic Modes on Uplink and Downlink Ports for Traffic Load Balance and Redundancy | |
Performance Enhancement Functions |
Bandwidth Control from 1Mbps to the Port’s maximum Rate (in steps of 1Mbps) |
Broadcast Storm Control: User-configurable from 1pps (Packet per Second) |
D-Link Safeguard Engine |
CPU Interface Filtering | |
Firmware Upgrade |
Management Support |
Single IP Management (SIM) v1.6 |
Command Line Interface (CLI) |
RMON v1 Monitoring |
Telnet Client |
Telnet Server (Up to 8 Sessions) |
SYSLOG |
Dual Images |
Web GUI Traffice Monitoring |
Web-based MAC Address Browsing |
RFC 2030 SNTP (Simple Network Time Protocol) |
SNMP v1, v2c, v3 |
Bootp/DHCP Client |
DHCP Relay Option 82 |
Loopback Detection |
Password Recovery |
Three-level User Account | |
MIBs |
802.1Q Q-BRIDGE-MIB (RFC 2674) |
802.1p P-BRIDGE-MIB (RFC 2674) |
MIB-II (RFC 1213) |
Bridge MIB (RFC 1493) |
RMON MIB (RFC 1757) Group 1, 2, 3, 9 (Alarm, Statistics, History, Event) |
IGMP MIB (RFC 2933) |
IF MIB (RFC 2933) |
Ethernet-like MIB (RFC 1643) |
PING-MIB and TRACEROUTE-MIB (RFC 2925) |
ICMP Ping by MIB |
Rate Limiting by MIB |
Save Configuration by MIB |
802.1w Setting and Read by MIB |
Port Interface MIB-II Trap (RFC 1215) |
D-Link Enterprise MIB | |
Optional SFP Transceivers |
DEM-310GT |
SFP Transceiver for 1000BASE-LX, Single-mode Fiber, Maximum Distance 10km, 3.3v | |
DEM-311GT |
SFP Transceiver for 1000BASE-SX, Multi-mode Fiber, Maximum Distance 550m, 3.3v | |
DPS-200 |
60-watt Redundant Power Supply | |
DPS-800 |
2-slot Redundant Power Supply Chassis | |
DPS-900 |
8-slot Redundant Power Supply Chassis | |
Management Software |
DS-510 |
D-View® 5.1 SNMP Network Management Program | |
Warranty Information |
Warranty |
Ordering Information |
Part Number |
DES-3550 |
xStack 48-Port 10/100BASE-TX Switch with 2 Combo SFP/1000BASE-T Gigabit Ports | |
DES-3526 |
xStack 24-Port 10/100BASE-TX Switch with 2 Combo SFP/1000BASE-T Gigabit Ports | |
DEM-310GT |
SFP Transceiver for 1000BASE-LX, Single Mode Fiber, Maximum Distance 10Km | |
DEM-311GT |
SFP Transceiver for 1000BASE-SX, Single Mode Fiber, Maximum Distance 550M | |
DPS-200 |
DPS-800 |
2-Slot Redundant Power Supply Chassis | |
DPS-900 |
8-Slot Redundant Power Supply Chassis | |
DS-510 |
D-View 5.1 SNMP Network Management Program | |
