DWL-G700APEOL EOS
Wireless 54Mbps Access Point
תאור
Product Description:
Works With:
Wireless Network Storage Enclosure Wireless Network Storage Enclosure
DSM-G600
More...
D-Link, an industry leader in networking, introduces the new
D-Link AirPlus™ G DWL-G700AP Access Point. With the ability to transfer files with a maximum wireless signal rate of up to 54Mbps*, the DWL-G700AP gives you high-speed wireless network access for your home or office.
The DWL-G700AP is Wi-Fi IEEE 802.11g compliant, meaning that it can connect and interoperate with other 802.11g compatible wireless client devices. The G700AP is also backwards compatible to 802.11b.
Centrino
Wi-Fi Certified
The D-Link DWL-G700AP Access Point has been verified and successfully passed through the Intel Wireless Verification Program, which tests the compatibility of various access point devices and wireless service providers with common configuration of notebooks built on Intel® Centrino™ mobile technology**.
With its web-based setup wizard, the DWL-G700AP Access Point ensures that you will be up and running on a wireless network in just a matter of minutes. The DWL-G700AP also includes an embedded DHCP server that can automatically assign IP addresses to wireless network clients.
The DWL-G700AP Access Point features Wi-Fi Protected Access (WPA) and 64/128-bit WEP Encryption to provide an enhanced level of security for wireless data communications. The DWL-G700AP also includes additional security features to keep your wireless connection safe from unauthorized access.
With easy-to-use Web-based management, the DWL-G700AP Access Point is the right choice for setting up your first wireless network or extending the range of an existing wireless network.
* Maximum wireless signal rate derived from IEEE Standard 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
** This wireless access point product has been verified for basic compatibility with corresponding Intel® Centrino™ mobile technology based notebooks. Notebooks based on Intel Centrino mobile technology do not support proprietary 802.11g performance enhancement features. Data rate features and performance may vary based on the configuration of your notebook and other factors.
Intel, the Intel Inside Logo, Intel Centrino and the Intel Centrino logo are trademarks or registered trademarks of Intel Corporation or its subsidiaries in the United States and other countries
מאפיינים כללים
2.4GHz Wireless LAN
802.11g Indoor Wireless Access Point
The AirPlus G DWL-G700AP is an 802.11g standard high-speed wireless access point designed for cost-effective home and
small office wireless connection. This device features the latest advanced wireless silicon chip technology with enhanced
security to shield and protect your wireless communication from intruders. It provides high network speeds of up to 54Mbps
when used with other 802.11g standard wireless products, delivering throughput speeds capable of handling heavy data
payloads.
Up to 54Mbps Wireless Speed
Easy Migration to Higher Bandwidth
The DWL-G700AP access point provides speeds of up to
54Mbps when used with other 802.11g equipment. This
enhanced speed and adoption of 2.4GHz frequency, now
available for public use in most countries, plus the mobility
and convenience inherent in a wireless LAN, make this
device an ideal solution for bandwidth intensive wireless
applications at home and office.
The DWL-G700AP access point is backward compatible with
802.11b standard wireless devices, providing seamless
interoperability with the earlier standard equipment. By
maintaining compatibility with your existing wireless network
equipment, this device lets you upgrade to a higher speed
while protecting your past investments in networking.
Advanced Network Security
The DWL-G700AP provides maximum security by
supporting standard WEP 64/128-bit data encryption and
Wi-Fi Protected Access (WPA), which includes support for
TKIP (Temporal Key Integrity Protocol), Pre Shared Key
(PSK) and 802.1x user authentication (used in conjunction
with a RADIUS server). In addition, this AP also supports
the latest-standard WPA2 that features AES (Advanced
Encryption Standard) with backward compatibility with
WPA. The access point includes an embedded DHCP server
network clients for network access. MAC Address Filtering
and Disable SSID Broadcast are some other highlights of
this wireless AP, designed to give everything a network
administrator needs to set up a robust wireless network
security.
802.11g 2.4GHz standard
Up to 54Mbps wireless data transfer rates
10/100BASE-TX port for connection to Ethernet or
DSL/cable modem
Compatible with existing 802.11b wireless devices
Built-in DHCP server for multiple user access
64/128-bit WEP data encryption
WPA and the latest standard WPA2 security support
Web-based configuration & management
* Maximum wireless signal rate based on standard 802.11g specifications. Actual
data throughput will vary. Network conditions and environmental factors may
תקנים
הורדות
איורים
DWL-G700AP
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
