DGS-3450EOL EOS
מתג מנוהל 48 פורטים +Layer2 במהירות 10/100/1000 + בנוסף 4 פורטים Combo 1000Base-T/Mini GBIC SFP ו-2 סלוטים להרחבות
תאור
The xStack DGS-3400 series of next generation switches delivers performance, flexibility, security, multi-layer Quality of Service (QoS) and redundant power option for the SMB and enterprises. With high Gigabit port densities for desktop connections, SFP fiber connectivity, 10-Gigabit uplink options and enhanced Layer 2+ functions, these switches comprise the workgroup access-layer stack for seamless integration with L3 core switches to form part of a multi-level network structured with high-speed backbone and centralized servers.
Unparalleled Flexibility.
Any switch in the DGS-3400 series can operate as a stand-alone device or part of a scalable stack. Embedded with Single IP Management capability, a stand-alone switch can form part of a virtual stack, where intra-stack traffic flows through the usual network wires, doing away with the costly stacking cables. Without stacking cables, cable distance barriers and physical stacking limitations, a virtual stack can comprise units that are located anywhere on the network that minimizes the impact of any single point of failure.
Redundant Ring Stacking.
Alternatively , optional 10-Gigabit modules can be installed in the open slots to create a physical stack. Up to 12 units or 576 Gigabit ports can be configured 1 for a stack. Users can install one or two single-port modules, depending on whether the linear or fault-tolerant Ring stacking is implemented. With each of these ports providing 20Gbps full duplex transmission on the cost-effective coaxial cable, the DGS-3400 series provides not only high-bandwidth stacking but also cost control capability that allows users to add ports strictly on a per need basis. Modules with single 10-Gigabit XFP can also be installed in any of the open slots for uplink to servers or a fiber backbone.
More Intelligent Than Simple Layer 2 Switches.
The DGS-3400 series provides a complete set of security features, which includes L2/L3/L4 multi-layer Access Control Lists and 802.1x user authentication via TACACS+ and RADIUS servers. In addition, it offers suppression capabilities and Layer 3 IP v.4/v .6 Static Routing to increase network performance and security. Built-in D-Link ZoneDefense technology allows business to integrate the switch stack with D-Link NetDefend firewalls to implement a full coverage, proactive security architecture.
Security, Performance & Availability.
The DGS-3400 series provides extensive VLAN support including GARP/GVRP and 802.1Q VLAN to enhance security and performance. To support converged applications including VoIP , ERP, Intranet and video conference, a robust set of L2/L3/L4 QoS/CoS features ensures that critical network services are served with proper priority. For prevent malicious flooding traffic caused by worm/virus infections, the DGS-3400 series provides D-Link Safeguard Engine to increase the switch's reliability, serviceability and availability. Bandwidth Control can be flexibly set for each port using pre-defined thresholds to assure a committed level of service for end users. For advanced applications, per-flow bandwidth control allows easy fine-tuning of service types based on specific IP addresses or protocols.
מאפיינים כללים
Interface
Ports
48 10/100/1000BASE-TX Auto-Negotiating, Auto-MDI/MDIXPorts with 802.3x Flow Control
Combo Ports
4 Combo SFP Slots, Media Support Dependent On GBIC Transceiver
Open Slot for 10-Gigabit Uplink Modules
2 Open Slots for 10Gigabit Uplink Modules
Diagnostic LEDs
Per Device: Power, Console, RPS
Per Gigabit Port: Link/Activity, 10/100Mbps or 1000Mbps Speed
Per Ethernet Port: Link/Activity, 10Mbps or 100Mbps Speed
RS-232 Console Port
1
Option 10-Gigabit Uplink (Transceivers sold separately)
Single XFP Slot Module (DEM-410X)
Yes
Single CX4 Port Module (DEM-410CX)
Yes
10GBASE-SR (300 m Multi-Mode Fiber) Support
Yes
10GBASE-LR (10 km Single-Mode Fiber) Support
Yes
Maximum Number of 10-Gigabit Uplinks Installable
2
Performance
Switch Fabric
136Gbps
Packet Forwarding Rate
101.19Mpps
Packet Buffer
750KB
MAC Address Table
8K Entries
IP v4 Routing Table
128 Entries
IP v6 Routing Table
128 Entries
IP v4 Host Table
2K Entries
IP v6 Host Table
1K Entries
Jumbo Frame Size
9,216 Bytes
Power
Internal Power Supply
100 to 120VAC, 200 to 240VAC, 50/60Hz
Maximum Power Consumption
131.3 Watts
Optional Redundant Power Supply
DPS-500
Physical/Environmental
Ventilation
2 40x40 mm DC Fans
Heat Dissipation
448.02 BTU/Hr.
MTBF
78,517 hours
Acoustic
< 48.7dB
Temperature
Operating: 32° to 104°F (0° to 40°C)
Storage: -40° to 158°F (-40° to 70°C)
Humidity
Operating: 10% ~ 90% Non-condensing
Storage: 5% ~ 90% Non-condensing
Dimensions
17.3 x 15.3 x 1.7 inches (441 x 389 x 44 mm)
19-inch Standard Equipment Rack Mount Width, 1U Height
Weight
11.6 lbs (5.27 kg)
Emissions
FCC Class A, CE, C-Tick, VCCI
Safety Compliance
CSA International, CB
Software Functions
L2 Features
IGMP Snooping Supports
IGMP Snooping v1, v2, v3
1K IGMP Snooping Groups
IGMP Fast Leave
Host-based IGMP Fast Leave *
Spanning Tree
802.1D STP
802.1w RSTP
802.1s MSTP
MLD Snooping Supporting 511 MLD Snooping Groups
Loop Back Detection
32 802.3ad Link Aggregation Groups
Back Pressure Flow Control
Trunking Across Stack
Head-of-line Blocking Prevention
Port Mirroring
One-to-One
Multiple-to-One
ACL modes *
VLAN
802.1Q
Double VLAN
Maximum 4K Static VLAN Groups
GVRP
Guest VLAN
802.1v
MAC-based VLAN
L3 Features
128 IP v.4/v.6 Static Routing
QoS (Quality of Service)
Per Flow Bandwidth Control
802.1p Support
8 Queues per Port
Queue Handling
Strict
Weighted Round Robin (WRR)
CoS Based on:
Switch Port
MAC Address
802.1p Priority
VLAN
Protocol Type
TOS
DSCP
IP v.4/v.6 Address
IP v.6 Traffic Class
IP v.6 Flow Label
TCP/UDP Port
User Defined Packet Content *
ACL (Access Control List)
Up to 768 Access Rules:
Switch Port
MAC Address
802.1p Priority
VLAN
Protocol Type
TOS
DSCP
IP Address
IP v.4/v.6 Address
IP v.6 Flow Label
TCP/UDP Port
Time-based ACL
CPU Interface Filtering
ACL Statistic *
Security
RADIUS/TACACS/TACACS+
SSH v.2
SSL v.3
Port Security
802.1x Port-based/MAC-based Access Control
Web-based Access Control *
MAC-based Access Control *
Broadcast Storm Control
Traffic Segmentation
IP-MAC-Port Binding (500 entries per device)
D-Link Safeguard Engine™
Support Microsoft NAP
Management
D-Link Single IP Management v.1.6
Web-based GUI
CLI
Web GUI Traffic Monitoring
Web MAC Address Browsing
Telnet server
Telnet client *
TFTP client
SNMP v.1, v.2c, v.3
SNMP trap on MAC Notification
RMON v.1
BootP/DHCP client
DHCP auto-configuration
DHCP relay option 82
System log
Trap/alarm/log severity control
vFlash file system
Dual Images
Dual Configuration
CPU Monitoring
LLDP *
MIBs
MIB-II (RFC 1213)
Bridge MIB (RFC 1493)
SNMP v.2 MIB (RFC 1907)
RMON MIB (RFC 1757, 2819)
RMON v.2 MIB (RFC 2021)
Ethernet-like MIB (RFC 1643, 2358, 2665)
802.1p MIB (RFC 2674)
IF MIB (RFC 2233, 2863)
RADIUS Authentication Client MIB (RFC 2618)
RADIUS Accounting Client MIB (RFC 2620)
Ping/Traceroute MIB (RFC 2925) *
D-Link enterprise MIB
Warranty Information
Warranty
lifetime warranty
Ordering Information
Part Number
Description
DGS-3426P
xStack Layer 2+ 24-Port Gigabit PoE Switch with 4 Combo SFP Ports and 2 10Gigabit Slots
DGS-3427
xStack Layer 2+ 24-Port Gigabit Switch with 4 Combo SFP Ports and 3 10Gigabit Slots
DGS-3450
xStack Layer 2+ 48-Port Gigabit Switch with 4 Combo SFP Ports and 2 10Gigabit Slots
DEM-310GT
SFP Transceiver for 1000BASE-LX, Single Mode Fiber, Maximum Distance 10Km
DEM-311GT
SFP Transceiver for 1000BASE-SX, Muti Mode Fiber, Maximum Distance 550m
DEM-410CX
1-Port CX-4 10Gigabit Module with 1 Meter CX-4 Cable
DEM-410X
1-Port XFP 10Gigabit Module
DEM-421XT
XFP Transceiver for 10GBASE-SR, Multimode Fiber, Maximum Distance 300m
DEM-422XT
XFP Transceiver for 10GBASE-LR, Singlemode Fiber, up to 10Km
DPS-500
Redundant Power Supply (for DGS-3427/DGS-3450)
DPS-600
Redundant Power Supply (for DGS-3426P)
DPS-800
2-Slot Redundant Power Supply Chassis (for DPS-500)
DPS-900
8-Slot Redundant Power Supply Chassis (for DPS-500)
DV-600S
D-View 6.0 SNMP Network Management Software, Standard Version
DV-600P
D-View 6.0 SNMP Network Management Software, Professional Version
תקנים
הורדות
איורים
DGS-3450/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
