DGS-1016D/GEEOL EOS
מתג שולחני 16 פורטים 10/100/1000 + קיט לארון 19"
תאור
 Main Features
  • 16 x NWay 10/100BASE-TX Fast Ethernet Ports
  • Full and half duplex support for each port
  • All ports support auto-negotiation function
  • Desktop sized, Saving space
  • Supplied with 19"
  • rack-mount kit
  • Product Description
    Power Savings by Number of Connected Ports and Link Status
    Computers do not require Internet access all the time; neither do switches utilize all ports at all times. When a computer or network equipment is shutdown, switches often remain on and continue to consume considerable amount of power. With Green Ethernet technology, D-Link switches can automatically detect link status and reduce power usage of ports that are idle. Computers or any connecting parties set to standby mode (not power off), however, will not provide significant power savings.
    Click here to see larger animation
    Power Savings by Cable Length
    The Green Ethernet switches have the ability to analyze the length of any Ethernet cable connected to them for adjustment of power usage accordingly. Shorter lengths require less power.
    Overall Power Savings Per Day
    For a traditional switch, power consumption remains constant even when the ports are not in use. In a standard workday scenario where PCs are used for 10 hours a day and powered off 14 hours a day, and connected to the switch using 20 meter cables, D-Link's Green Ethernet can save up to 20%* power used for each system.
    Note: Switch uses switching power adapter. The cable length which PCs are connected to switch is 20m cables.
    Get the blazing speed of Gigabit Ethernet with the D-Link GigaExpress DGS-1016D, an 16-port 10/100/1000Mbps Gigabit Switch that delivers power, performance, and reliability in one cost-effective, space-saving design. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality.
    Power users in the office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly. The versatile and compact 1RU height design of the DGS-1016D enables the device to be rackmounted in a standard 19 inch rack, while conserving valuable rack space.
    Power-Packed
    It features a non-blocking switching architecture that filters and forwards packets at full wire-speed for maximum throughput. An 8K MAC address table provides scalability for even the largest networks. Address learning and aging, 802.3x Flow Control for full-duplex mode, and back pressure flow control for half-duplex mode alleviates traffic congestion and ensures reliable data transmission.
    Designed using industry standards, it is compatible with virtually all 10, 100, and 1000Mbps Ethernet devices and other vendor equipment. The D-Link DGS-1016D 10/100/1000 Mbps Gigabit Switch protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds.
    Easy to use
    The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
    It also features diagnostic LEDs which display status and activity, allowing you to quickly detect and correct problems on the network. Every port also supports a cable diagnostic feature that helps to detect cable related problems.
    * Power savings may vary depending on products used.
    Maximize power savings when compared to a D-Link conventional switch. Uses up to 40% less energy when connected devices are powered down and up to 20% less energy when connected devices are used 10 hours and powered down 14 hours over a 24-hour period, when connected via 20 meter Ethernet cables.
    מאפיינים כללים
    MAC Address Table Size
    8K
    Switch Fabric
    32Gbps Forwarding Capacity
    Transmission Method
    Store-and-Forward
    Diagnostic LEDs
    Per Unit: Power
    Per Port: Activity/Link, Speed
    Packet Buffer Memory
    340Kbytes Buffer Memory per Device
    QoS
    802.1p (4 Queues)
    Interface Options
    RJ-45
    10BASE-T, 100BASE-TX & 1000BASE-T
    Network Protocol and Standards
    IEEE
    802.3 Ethernet, 802.3u Fast Ethernet, 802.3x Flow Control, 802.3ab Gigabit Ethernet, 802.1p QoS
    Electrical & Emissions Summary
    Emissions
    FCC Class A, CE Class A
    Power Supply
    100-240VAC, 50/60 Hz Internal Universal Power
    Environmental
    RoHS Compliant
    Safety and Environmental
    Safety
    CSA + NRTL/C
    Temperature
    Operating: 32° to 104°F (0° to 40°C)
    Storage: 14° to 131°F (-10° to 55°C)
    Humidity
    Operating: 5% to 95% RH (Non-Condensing)
    Physical Specifications
    Dimensions (W x D x H)
    280mm x 180mm x 44mm
    Weight
    1.75Kg
    Warranty
    Warranty
    2-Year Limited
    Ordering Information
    Part Number
    Description
    DGS-1016D
    16-Port Gigabit Switch, Rackmount/Desktop
    תקנים
    הורדות
    איורים
    DGS-1016D/GE
    מראה מקדימה
    מראה מאחורה
    דף מידע
    ראה גם
