חיפוש מהיר
תכונות המוצר:
1.2 m KVM Cable with VGA and PS/2
תאור:
The DKVM-CB/1.2M/B 1.2 m KVM cable is designed for connecting PC to the D-Link DKVM-4K/B KVM switch. The cable is equipped with 6-pin mini-DIN connectors for connecting to PS/2 keyboard and mouse ports on the PC and 15-pin HDB connectors for connecting to VGA port on the PC and on the KVM switch.
The DKVM-CB/1.2M/B combines several cables in one assembly, thus allowing you to save space on your table. Each connector has its own colour code (PC99), ensuring correct connection.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
