The
answer to expensive, outmoded, analog CCTV surveillance systems has
arrived. When coupled with D-Link’s high-resolution and feature-rich IP
cameras, the Network Video Recorder (NVR) offers a comprehensive video
display, storage, and management solution. The D-Link NVR provides
reliable high-quality remote monitoring functionality at a fraction of
the cost of conventional surveillance systems.
Instant Live View
D-Link’s intuitive GUI interface simplif es viewing live and
recorded video from the NVR. The camera status page shows
connection and recording status, along with frame rate and bit rate
information for each camera. Total available recording time for the
system is also clearly displayed for each NVR.
Live Monitoring & Camera Adjustment
Users are provided with a variety of options for viewing and organizing
camera footage on-screen. For a system with multiple channels, users can
simply drag and drop selected cameras to the viewing area.
Camera names and recording status is displayed via OSD to aid
in identif cation. Presets from within the interface can be set to
instantly restore a previously saved view. A single camera may be viewed
full-screen with optional two-way audio. Users can control
pan/tilt/zoom (PTZ) functions from within the interface using the
provided interface buttons or by directly clicking on the video.
Extensive Recording Functionality
A clear single-page interface assists with conf guration including
compression, resolution and frame rate for all connected cameras. The
NVR records video from up to 4 local and remote IP cameras. A
total of 4 NVRs can be combined and administered with D-Link’s
bundled 16 channel management software.
Once cameras have been set up, a highly conf gurable
scheduling system allows for continuous recording or recording
during specif cally allotted timeframes. Each camera can be set
to record independently at preset intervals. The DNS-726-4 also
provides event recording based on specif c triggers.
The NVR can be conf gured to overwrite the oldest data
automatically when HDD space runs out, allowing for continuous and
uninterrupted recording. Users can specify the number of days the
recording should be kept (within the limits of the HDD capacity). For
example, if the NVR has the capacity to store 7 days of recording, using
the overwrite option, the NVR will record the 8th day and
delete the 1st day.
The NVR also provides the option to stop recording when
the HDD is full. Should the disk reach capacity, a notif
cation can be sent via e-mail or to an external device such as
an audible alarm or LED display via the DI/DO interface.
Powerful Event Management
The NVR centrally controls the digital output, e-mail notif
cations and recording for all the connected cameras. Input
triggers from camera motion detection or digital input interfaces can
additionally be monitored. These events will be logged, with optional
notif cations via e-mail or output devices. Users can set up multiple
contact lists for event notif cation. A straightforward logging
system organizes events by date for easy recall.
Intelligent Playback
Searching through recorded data can be tedious and frustrating.
However, the NVR’s smart search function makes detecting notable
events effortless. By selecting a target area on the video and setting
search sensitivity, the smart search will traverse the video database
based on specif ed search criteria to locate noteworthy events. Search
criteria include options such as motion detection,
missing or abandoned object, lost focus or camera occlusion.
(DNS-726-4 only)
After selecting a desired video period for display, the NVR can
instantly begin playback. The DNS-726-4 supports 4 channel
simultaneous playback and the DNS-722-4 supports 1 channel
playback. Playback speed control allows for up to 16x speed fast
forward or fast backward play. The step playback option displays
one frame at a time. Additionally, users can enhance the
recorded video with controls such as brightness, contrast, and
sharpness.
During playback, if a user uncovers video that needs to be
exported, two formats are available. The AVI format will export raw
video. The ASF f le format will transpose a timestamp on the exported
video. If a printer is connected to the user’s PC, the NVR can also
print the selected still image.
Comprehensive Data and Hardware Security
The D-Link NVR ensures the security and integrity of IP camera
footage. Administrators may flter external connections to the
NVR by IP address, limiting access and thus increasing
security. Administrators may also choose access privileges for
users by specifying the cameras they may access to for live
view, playback, audio and PTZ functions.
Recorded data is stored in a secure database. This recorded
data can be backed up to additional storage locations
periodically or whenever needed. The NVR also includes the
option to protect data using a RAID 1 confguration. RAID 1 duplicates
the recordings database onto two separate drives. In the event of an HDD
failure, data integrity is maintained on the secondary HDD.
A UPS can be used as emergency power supply for the NVR. The UPS uses
a USB interface to notify the NVR to perform a proper shutdown
before battery power runs out. In the event of a power failure
without a UPS, the NVR will boot up automatically once power is
restored.
Of course, the security of data is irrelevant unless the
device itself is protected from theft. For this reason, the sleek NVR
enclosure is compact and easy to conceal in a secure remote location. A
front panel lock protects the HDD and a rear panel lock can be used to
secure the NVR with a cable.
Complete Network Functionality
The D-Link NVR takes advantage of existing network architecture,
taking advantage of features such as PPPoE and ADSL services. The NVR
can acquire an IP address from a DHCP server to become easily searchable
during installation. Dynamic DNS is supported for systems
operating without a fxed IP address. The NVR can then be reached from
the internet using an easy to remember domain name provided by the DDNS
service. Maintaining an accurate record of time is essential if
recorded data is to be used as evidence. To ensure that the
recorded time is always accurate, the NVR can update the system
clock from an internet server using the Network Time Protocol
(NTP).
D-ViewCam NVR Software
The D-ViewCam NVR software bundled with the D-Link NVR consists of
three main components: Playback Manager, Backup and File
Manager, and Multi-NVR Viewer. The “Multi-NVR Viewer1” supports
simultaneous display of up to 16 channels. Easily organize the view by
directly dragging and dropping video onto the display window.
Cameras managed by the NVR can be viewed as individual sites or
categorized into groups. The “Playback Manager” includes a clean
and simple web GUI interface that allows users to play, search or
export video. The Backup and File Manager” is a fexible backup utility
that simplifes the process of backing up video data from the NVR to
external storage.
Network Setup Using D-Link NVR
4 Channel Live View
