חיפוש מהיר
תכונות המוצר:
מערך אחסון iSCSI SAN מסדרת xStack, עד 15 דיסקים נשלפים SATA-II ויציאת 10Gb אחת לרשת
מאפיינים כללים
מאפיינים כללים:
Drive Bays
15
Drive Interface Support
SATA-II support
System Memory
256MB to 512MB (512MB standard)
Cache Memory
256MB to 4GB (512MB standard)
Battery Backup for Cache
Standard (approximately 72 hours on full charge)
Bandwidth
Up to 1,160Mbytes per second
Storage Capacity
15TB capacity with 1TB hard drives (supports higher capacity drives as they are introduced)
Operating Systems Supported
Windows® Vista® 32-bit & x64 (Ultimate & Enterprise) w/Built-in iSCSI initiator
Windows Server 2003® 32-bit & x64 SP1 (Standard & Enterprise) w/v2.04 iSCSI initiator
Windows Server 2003 R2 32-bit & x64 (Standard & Enterprise) w/v2.04 iSCSI initiator
Windows XP Pro 32-bit & x64 w/v2.04 iSCSI initiator
Windows 2000 Advanced Server w/v1.6 & v2.01 iSCSI initiator
Fedora® Core® 6 & 7
Red Hat® 7.3
Red Hat 9
Red Hat Enterprise® WS 3 update 4
Red Hat Enterprise ES 4 update 4 & 5 32-bit & x64
Red Hat Enterprise AS update 4
SuSE® Professional 9.3 32-bit & x64
Apple OS® X (10.4.7 | 10.4.8 | 10.4.10) w/Intel® and Power PC CPUs
Supported NICs, iSCSI Accelerators and iSCSI HBAs
Intel® Pro 1000MT & XT [1GbE]
Intel Pro 10000 CX4 [10GbE]
Chelsio® S210X-SR-XFP (S2iO) [10GbE]
Neterion® Xframe® II & Xframe E [10GbE]
Alacritech® SES2104ET (drivers: SNP 9.1.0.1092 & 7.3.1.0)
Alacritech SES2102ET (drivers: SNP 9.1.0.1092 & 7.3.1.0)
QLogic® 4010C
QLogic 4052C
iSCSI Network Interface
One (1) 10GbE Fiber (XFP transceiver sold separately)
Host Interface
iSCSI Draft 20 compliant initiator
Connections
1,024 hosts
CHAP Authentication
Yes
Access Control of Management
Yes
iSCSI/TCP/IP Full HW Offload
Yes
Jumbo Frames Support
Yes
LAG Support (Link Aggregation)
Not Applicable
VLAN Support
Up to eight (8). 1-to-1 mapping between IP subnet and VLAN. Multiple VLANs per physical port with VLAN tag
Volume & RAID Support
RAID Controller
Single- Integrated in ASIC
RAID Support
RAID Levels 0, 1, 1+0 and 5
(Striped sets, mirrored sets, striped mirrored sets and parity sets)
Volumes
1,024 Virtual Volumes (256 accessible per initiator)
Target Nodes
1,024
Online Capacity Expansion
Yes
Hot Swappable Drives
Yes
Instant Volume Access
Yes
Free Space Defragmentation
Yes
Auto-Detection Failed Drive
Yes
Auto-Rebuild Spare Drive
Yes
RAID Level Migration
Yes
Drive Roaming in Power Off
(configured drives are not bay-specific)
Yes
Micro Rebuilds
Yes
Storage Management
Embedded IP-Based Management GUI
Create, manage, expand and monitor storage pool, volumes and RAID
Event manager to view and persist events
Firmware Field Upgradeable
Yes
SMI-S Version 1.1
Yes
Power
Supply Type
Redundant 3U 2+1 760 Watt
Input Voltage
90-264 VAC (auto-switching)
Input Frequency
47-63 Hz
Input Current
20A Maximum at 90VAC and 10A Maximum at 264VAC
(maximum amps vs. voltage varies linearly throughout this voltage range)
Power Factor Correction
95%@110V, Full load
Power Consumption
570W (full configuration)
Thermal
2000 BTU / hour (full configuration)
Environmental
Operating Temperature
32 to 104 degrees F / 0 to 40 degrees C
Storage Temperature
-4 to 158 degrees F / -20 to 70 degrees C
Operating Humidity
20 to 90% non-condensing
Storage Humidity
10 to 95% non-condensing
Physical (approximate)
Form Factor
3U industry-standard 19-inch rack
Height
5.2 inches / 13.3 centimeters
Width
17.25 inches / 43.8 centimeters
Depth
22.5 inches / 57.1 centimeters
Weight
73 pounds / 33 kilograms (full configuration)
International Approvals
Emissions
CE Class A, FCC Class A, C-Tick Class A, VCCI Class A
Safety
CSA 60950-1, UL60950-1, IEC 60950-1, EN 60950-1
Warranty and Support
Warranty
2 Years on DSN-3400 (manufacturers warranty on hard drives)
Extended Warranty
Available
Support
1 year 9 hours per day / 5 days per week Technical Support
Available Configurations
DSN-3400-10
xStack 1x10GbE iSCSI SAN Array, 15 Bays, 3U, w/o Drives, with Trays
DSN-3400-20
xStack 1x10GbE iSCSI SAN Array, 15 Bays, 3U, w/o Drives, w/o Trays
DSN-3200-10
xStack 8x1GbE iSCSI SAN Array, 15 Bays, 3U, w/o Drives, with Trays
DSN-3200-20
xStack 8x1GbE iSCSI SAN Array, 15 Bays, 3U, w/o Drives, w/o Trays
Available Accessories
DSN-111-400
400GB SATA-2 Hard Disk Drive + Hot Swap Tray
DSN-111-500
500GB SATA-2 Hard Disk Drive + Hot Swap Tray
DSN-111-750
750GB SATA-2 Hard Disk Drive + Hot Swap Tray
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה
