DCS-1000WEOL EOS
תאור
The DCS-1000 series Internet Camera is a standalone system connecting directly to an Ethernet or Fast Ethernet network. This camera also supports wireless transmission based on the IEEE 802.11b standard.
All-in-one System
This Internet Camera is different from conventional PC cameras in that it is an all-in-one system with built-in CPU and web-based solutions. The camera provides a low cost solution for transmission of high quality video images for monitoring. It can be managed remotely, accessed and controlled from any desktop or notebook PC over the Intranet or Internet via a web browser.
Image Monitoring From Multiple Users
Up to 64 users can log onto the camera at the same time to monitor images. The camera utilizes the JPEG image compression technology, providing high quality images for users. JPEG is adopted since it is a standard for image compression and can be applied to various web browser and application software without the need to install extra software.
Flexible Wireless Transmission Range
Model DCS-1000W camera comes with a wireless LAN interface. The antenna of this wireless camera can be changed for a variety of reasons such as extending the wireless transmission range. Generally the wireless distance can go up to 100 meters indoors and up to 300 meters outdoors. The range are limited by the number of walls, ceilings, or other objects that the wireless signals must pass through. Typical ranges vary depends on the types of materials and background Radio Frequency (RF) noise in your home or business and the configuration setting of your network environment.
Image Capture and Recording
You can capture images both as snapshots of single images or video images from the IPView application supplied with the CD-ROM of the camera.
Indoor Installation
The Internet camera is designed for use indoors. It is not weatherproof, and needs to be equipped with a weatherproof case to be used outdoors.
Connection to Ethernet-based Server
The camera provides a 10/100Mbps port, allowing connection to a Fast Ethernet server. The camera can be connected to a LAN with private IP addresses.
Firewall Installation
If a firewall exists on the network, port 80 is open for ordinary data communication. However, since the camera transmits image data, the default port 8481 is also required. It is necessary to open port 8481 of the network for remote users to access the camera.
מאפיינים כללים
Video Specifications
Resolution
640 x 480 pixel
Sensor
1/3" color CMOS sensor
Gain control
Automatic
Exposure
Automatic
White Balance
Automatic
Shutter
Electronics 1/60 ~ 1/15000 secretary
Minimum Illumination
2.5lux@f1.4, 3000K Color
Focal Length
6.0 mm
Aperture
F=1.8
Focus Extent
20 cm -
Lens mounting
Fixed board lens, CS-mount type
Image (Video Setting)
Image compression
JPEG
Frame rate
30fps@QCIF, 20fps@CIF , 3fps@VGA
Compression Rate selection
5 level (Very Low, Low, Medium, High, V ery High)
Frame rate setting
1, 5, 7, 15, 20, auto (depends on the video format)
Video resolution
160x120, 320x240, 640x480
Brightness control
Range 1- 128
Contrast control
Range 1- 128
Hue control
Range 1- 128
System Hardware
LAN Connector
One RJ-45 port to connect to 10/100Mbps Ethernet, auto-sensed, wireless
Wireless LAN (DCS-1000W only)
Built-in 802.11b wireless LAN module (Wi-Fi compliant)
Wireless LAN Modulation Techniques (DCS-1000W only)
Direct Sequence Spread Spectrum (DSSS)
Wireless LAN Frequency Range (DCS-1000W only)
2.4 - 2.497GHz
Transmitter Output Power (DCS-1000W only)
12dBm
Generic I/O Port
4 I/O ports, 2 for input, and 2 for output
LED Indicator
- Power LED (Blue)
- LAN/WLAN Activity LED (Orange)
Slide Switch
LAN/LAN&WLAN/WLAN
Antenna Connectors
2 connectors (DCS-1000W only)
Communication Support
Wireless LAN Encryption
64 bit, 128 bit or OFF
Communication Protocols
HTTP, FTP , TCP/IP, UDP , ARP , ICMP, BOOTP , RARP, DHCP , PPPoE
System Requirements
Browser Support
- Internet Explorer 5.0 or above (ActiveX & JAV A Mode - View Image for windows
OS and JAV A Mode-View Image for other OS)
- CPU: Pentium II, 266 MHz or above
- Memory Size: 32 MB (64 MB recommended)
- VGA card resolution: 800x600 or above
- Netscape 6.0 or above (JAV A Mode - View Image)
IPView Application
- Win 98, Win 98 SE, Win 2000, Win Me, Win XP
- Pentium III, 450 MHz or above
- Memory Size of 128 MB (256 MB Recommended)
- VGA card resolution of 800x600 or above
תקנים
הורדות
DCS-1000W Internet Camera With 10/100Mbps Fast Ethernet Port + IEEE 802.11b Wireless LAN
