DCS-3411EOL EOS
תאור
D-Link DCS-3411 is a versatile day and night network camera, ideal for small-to-medium business applications and remote monitoring capabilities over the Internet. A D-Link DCS-3411 Camera can be placed anywhere including awkward locations through a PoE connection and can be connected to various external devices to provide a variety of security applications triggered on alarm-based events.
Key Features
Quality ¼” CMOS sensor for superior image rendering
Removable IR-cut filter for best results in low light conditions
Simultaneous Motion JPEG, MPEG-4 and H.264 streaming
Simultaneous video profiles for web viewing, 3G mobile viewing and video recording
16x digital zoom
Built-in 802.3af PoE for flexible placement
Digital I/O for connection to sensors and alarms
RS-485 port for connection to an external Pan/Tilt device
Direct recording to a NAS box or SD card (no software required)
3G mobile video, for live video streams on a 3G mobile phone or PDA
Built-in SD card slot for local recording
BNC connector for integration into an existing CCTV network
Free D-ViewCam software included
Supports 2-way audio*
High quality video streaming
The D-Link DCS-3411 camera employs a quality CMOS sensor with low lux
sensitivity to deliver a truly superior image quality. A built-in
Infrared Cut Removable (ICR) filter can be manually applied via the web
GUI, or set to automatically adjust according to lighting conditions.
This feature enables the camera to capture crisp colour images during
the daytime, and grayscale images in low-light.
A versatile solution
The D-Link DCS-3411 includes built-in support for 802.3af Power Over
Ethernet (PoE). This allows the camera to be powered directly from a PoE
Ethernet switch, providing users the freedom to place the camera
anywhere they want, including high walls and covert locations.
In addition, the camera is equipped with 2 digital input ports for sensors or alarms, 1 digital output port for an alarm, 1 power output port for an LED illuminator and a BNC connector which provides both analogue and digital interface video transmissions. An RS-485 port is also included for connection to external pan/tilt devices. Moreover, the 12V interface provides power for an optional LED illuminator. Additional items such as an auto iris lens, IR LED lens or a night vision illuminator can be added to the D-Link DCS-3411.
Recording & storage
The D-Link DCS-3411 supports 4 separate profiles simultaneously and is
capable of recording in MJPEG, MPEG-4 and H.264 compression with a
choice of resolutions for a smooth performance. You can save snapshots
and automatically start recording video and audio when motion is
detected. With the built-in Samba client, software is not required to
record the action directly on a network storage device. An SD-card slot
is also included for local storage.
Remote monitoring
With the D-ViewCam software included, up to 32 cameras may be monitored
on a single computer screen at one central location. The D-Link DCS-3411
also features 3G mobile video support, enabling you to view a live
video feed from the camera on a compatible 3G mobile phone or PDA
anywhere in your 3G coverage area.
מאפיינים כללים
Camera
¼” CMOS sensor
Minimum illumination: 0.5 Lux (F1.8)
CS mount lens: 6mm, F1.8
Field of view: 51° diagonal, 31°vertical, 41° horizontal
16x digital zoom
Built-in SD card slot for local recording*
RS-485 interface for connection to an external Pan/Tilt device
BNC connector to integrate the network camera into a CCTV network
Digital I/O support for sensors and alarms
Network
1 10/100Base-TX Ethernet port
802.3af Power over Ethernet (PoE) compliant
Dynamic DNS support
UPnP™support
Web-based configuration
Video
Motion JPEG / MPEG-4 / H.264 multi-profile compression
Up to 4 simultaneous video profiles
JPEG for still image
Adjustable image size and quality
Audio
Built-in microphone
External microphone input, external speaker output
Monitoring and recording
Live video streams from a 3G mobile phone or PDA
Remote management/control of up to 32 cameras via D-ViewCam software
Direct recording to a NAS device (no software required)
Event notification and snapshots/video clips upload via HTTP, SMTP, or FTP
*card not included
