DCS-20EOL EOS
עדשה עם Infrared indicator אינטגרלי למצלמות 3410 / 3420
תאור
D-Link’s SecuriCam IP Camera accessories provide cost-effective solutions for the diversity of application. The DCS-10 IR illuminator and DCS-20 IR lens can be used for both day and night surveillance, and the DCS-25 vari-focal CS lens provides easy installation without the need to change lenses for particular applications. Protect your home and business by maximizing the full potential of D-Link’s IP cameras and these beneficial accessories.
מאפיינים כללים
Supported Devices
DCS-3410
DCS-3420
Dimensions
58.6 (Ø)x24(D)mm (2.3 x.0.95 inches)
Weight
90g. (0.20lbs)
Distance
10 m
Focal Lenght
F6.0mm/F2.0
Power On
Auto-control under 10 lux
Power Consumption
160mA (max.)
