תאור
Powerful Surveillance
The D-Link® DCS-3415 Fixed Network Camera is a high-performance camera designed for high-end professional surveillance and security applications. Equipped with a Sony® 18x Optical Zoom lens and progressive scan CCD sensor, the DCS-3415 allows you to capture vivid images of moving objects that traditional interlaced scanning techniques cannot achieve and effectively reduces motion blur and distorted, jagged edges of recorded images delivering exceptional picture quality.
The built-in ICR filter in the DCS-3415 provides automatic Day/Night functionality, adjusting the image from color during the day (and in low-light conditions) to monochrome at night (or in extremely poor lighting conditions) while only requiring a minimum illumination of 0.38 lux. With features such as simultaneous MPEG-4/MJPEG streaming, multicast MPEG-4 streaming, PoE support, a built-in Compact Flash card slot, and connectivity to a variety of external devices, the DCS-3415 is an extremely versatile solution for high quality viewing and reliable recording throughout the day.
Multiple Streaming
The DCS-3415 supports simultaneous streaming of MPEG-4 and MJPEG video to provide both high quality and bandwidth efficient compression formats. MJPEG delivers greater file integrity, making it ideal for detailed monitoring situations. MPEG-4 has smaller file sizes, making it more useful for extended recording periods or for use in low bandwidth networks. Additionally, the DCS-3415 supports multicast MPEG-4 streaming allowing users to view content by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-3415 includes digital input and output ports (one each) allowing connectivity to external devices such as IR sensors, switches, and alarm relays. It also comes with a RS-485 interface, providing connectivity to an optional Pan/Tilt enclosure, which effectively adds pan/tilt functionality to the DCS-3415. Additionally, a 12V interface provides power for an optional LED illuminator.
3GPP Mobile Surveillance
Support for 3GPP Mobile Surveillance1 allows you to view a live video feed from your compatible Internet-ready mobile phone with a 3GPP player installed. This extends your monitoring capability without requiring the use of a computer, allowing you to check your camera’s video feed while on-the-go.
Additional Features
The DCS-3415 comes with a built-in microphone and audio ports allowing 2-way audio communication2 when an external speaker is connected and even includes an audio switch to ensure privacy when needed. The DCS-3415 also comes with a built-in Samba client for NAS so there is no need for a direct connection to a PC or any other hardware or software to capture and transfer images. Equipped with 802.3af Power over Ethernet (PoE) support3, the DCS-3415 can receive both power and data over a single Ethernet cable, allowing you to place this camera in locations without a power outlet.
Convenient Management
The included D-Link D-ViewCam™ 2.0 software enables you to manage up to 32 network cameras, set e-mail alert notifications, set recording schedules, and trigger motion detection to record directly to your hard drive. D-ViewCam also allows you to upload a floor plan of your business and create a realistic layout of where your cameras are located, further simplifying the management process
Product Description:
Outdoor Enclosure with Thermal Barrier
DCS-45
Industrial Grade Outdoor Enclosure with Power Supply
DCS-50
Industrial Grade Outdoor Enclosure with Power Supply, Heater, & Blower
DCS-60
מאפיינים כללים
Network protocol support
• IPV4, TCP / IP, RTSP / RTP / RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPNP, DDNS, PPPOE, IGMP, SAMBA-client filtering IP, 3GPP
Built-in network interfaces
• Port Ethernet 10/100BASE-TX, RJ-45 connector
Support video algorithms
• Save still images in JPEG format
• Compression formats: MJPEG and MPEG-4
• Supports two-way audio transmission (dual-streaming)
• MPEG-4 over UDP, TCP or HTTP
• Multicast flow of MPEG-4 MJPEG over HTTP
• Support for 3GPP Mobile Surveillance
• View Live Video: up to 10 clients
Video resolution
• MJPEG and MPEG-4 video with resolution up to 640x480 (VGA)
• 176 x 144 - up to 30 frames / sec
• 320 x 240 - up to 30 frames / sec
• 640 x 480 - up to 30 frames / sec
Functional videos
• Setting up the quality, size and speed of image transmission
• Time stamps and pasting text
• 3 windows to configure the motion detection
• Rotate and mirror image of the object
• Adjust the brightness of the image
• Automatic Gain Control (AGC), Automatic White (AWB), Automatic Exposure (AES)
Speed transmission of video
• 20Kbit / s - 4Mb / s
Sensor and Lens Specification
• Progressive scan, 1/4-inch SONY CCD-sensor
• Focus range: 4.1 mm to 73.8 mm
• F-number lens: F1, 4 (wide), F3, 0 (tele)
• Aperture: Auto / Manual (from F1, 4 and F22)
• Removable IR filter: Automatic / Scheduled / Manual
• 18x optical zoom (4X digital zoom)
• Viewing angle: 48 ˚ ± 2,8 ˚ (horizontal)
• Shutter speed: 1/2 sec. to 1/10000 sec.
• Minimum illumination: 1.61 lux (1/30 sec. At F1.4), 0.38 lux (1/30 sec. At F1.4, ICR ON)
Event management
• Weekly schedule for motion detection
• Notification of events and download photos shot / video using HTTP, SMTP, or FTP
• Ability to configure multiple HTTP-, SMTP-or FTP-servers
• Flexible customization of event notifications
• Use of multiple methods can facilitate the process of writing up
Audio
• Compression and transmission rate:
- Compression of a conversation (GCM-AMR), transfer rate: 4.75 kbit / s - 12.2 kbit / s
- Audio Coding (MPEG-4, AAC), transfer rate: 16 kbit / s - 128 kbit / s
• Interface: Built-in microphone jack for external microphone and speaker
• Support for SIP-protocol (two-way exchange of information)
• Hardware and software mute
Security
• Protection of administrator and user groups
• Password authentication
• Digital encryption, HTTP and RTSP
Functions of video surveillance software
• Remote management / control of up to 32 cameras
• View images from 32 cameras on one screen
• Supports all management functions through a Web-based interface
• Recording options on the operation of the sensor or manually
Remote management
• Setting up a Web-browser
• Getting the pictures / video and save the map CF, a local hard drive or NAS (network storage system) via Web-browser
System requirements
• Operating Systems: Microsoft Windows 2000, HP, Vista
• Web-browser: Internet Explorer, Firefox, Netscape, Mozilla, Opera
Mobile video surveillance 3GPP
• Mobile phone with 3GPP player
• Packet Video Player 3.0
• QuickTime 6.5
• Real Player 10.5
Ethernet interfaces
• Compliance with IEEE 802.3
• Compliance with IEEE 802.3u
• Supports full duplex mode
• IEEE 802.3x flow control for full duplex
• Supports IEEE 802.3af (PoE)
External interfaces of the device
• One D / I-interface and a D / O-interface for external sensor and alarm
• RS-485 interface for external scanner
• Output 12V DC
Indicators
• 2-light htsvetny
Data storage
• CF card slot for local recording of MP4 file
Package
• DCS-3415
• External power adapter
• Support for the camera
• Ethernet cable, Category 5
• Quick Installation Guide
• CD-ROM with User's Guide
