תאור
Stand-alone System With Integrated Web Server
This Internet Camera comes with a built-in CPU and Web server, providing a low-cost solution for security needs. Its integrated Web server eliminates the need to connect the camera to a computer. Once installed, you use the built-in IP address to gain access to the camera, view live streaming video, and make changes to camera settings.
Web-based Remote Access
You can install your camera at home then view the images from anywhere in the world on a computer running Internet Explorer. Directly connected to the Internet without going through any computer, this camera is simple to install and easily integrates with your network environment.
Automatic Camera Movement to View Different Angles
The camera is mounted on a motor for rotation to capture images from different angles. From a remote site, you can manually rotate the camera's horizontal and vertical movements. The camera movement angles can also be set up for automatic panning and tilting in rotation according a pre-set timing.
Multi-Camera Monitoring
Surveillance software is included to let you view up to 16 cameras on a single computer screen at one central location. Images can be recorded to your computer's hard drive manually or according to a pre-set schedule. The camera can be connected to external alarms and sensors, and you can set up automated email alerts for sending through the Internet to alarm you instantly of all unusual happenings.
Motion Detected Recording
Instead of recording 24 hours a day, 7 days a week, images can also be recorded only when motions are detected. This saves disk space and eliminates the time wasted to view unnecessary images. Images can be directly archived straight to your computer hard drive or to a Network Attached Storage. Playback consumes little time with triggered event browsing and fast database searching.
High-Quality Video & Sound
This camera uses MPEG-4 Short Header Mode to stream live video at up to 30 frames per second for real-time viewing. A CCD sensor provides sharp video images with lifelike color representation. The camera also features 4x digital zoom for close-up viewing using the Web interface. Plus, with low light sensitivity , it has the capability to monitor and record video in rooms with minimal lighting, making it ideal to use at night.
Ethernet and Wireless LAN Connection
A built-in microphone allows you to listen while watching live images. The camera can also be attached to an external, more powerful microphone and a TV in a private room, where you can monitor streaming images and listen to surveillance sound.The camera provides a 10/100BASE-TX port for connection to an Ethernet network without going through any PC for cost-effective surveillance in and around a building. This Ethernet port can also be used to connect to a broadband Internet via a home gateway router. It also provides an 802.11b+ wireless LAN interface, allowing you to do surveillance wirelessly in and around a building from a PC without connection to a wired network.
מאפיינים כללים
Hardware
Built-in Wireless LAN
- Sensor: 1/4-inch color CCD sensor, interlace scan mode, supports 380 TV lines
video output, up to 30 frames per second
- Pan range +/- 135 degrees
- Tilt range +90 to -45 degrees
- Automatic Gain control (AGC) 24dBi
- Automatic Exposure (AE)
- Automatic White Balance
- Electronics shutter 1/60 to 1/15000 second
- Minimum illumination 2.5lux @ f1.4
- Lens mounting: standard CS mount type lens, 6.0mm, f1.8
- 24-bit RGB, 4CIF/SIF, supports up to 704 x 480 (NTSC)/
704 x 576 (PAL) resolution
- MPEG4 short header mode compression
- Compression ratio: 5 levels
- Adjustable image size, quality and bit-rate
- Time stamp and text overlay
Video Sizes
QSIF/QCIF (30 fps), SIF/CIF (30 fps), 4SIF/4CIF (10 fps) (user-selectable)
Digial Zoom *
Up to 4x magnification
* 4x digital zoom enlarges an image by magnifying the pixels in a selected portion of the image by 4 times.
Audio
24kbps
Communication
- 1 RJ-45 auto-sensing 10/100BASE-TX port to connect to 10/100Mbps Ethernet
- Supported communication protocols: HTTP, FTP , TCP/IP, UDP , SMTP, DHCP, T elnet, NTP, DDNS, UPnP and DNS
Viewing System Requirement
Internet Explorer 5.x or above
Security
- Administrator and user group protected
- 15 digits password authentication
LED Indicators
- System power and status indicators
- Network link and speed indicators
Alarms and I/O
- Motion detection (activity detection)
- Periodical image transfers though e-mail and upload to a server, using FTP
- 1 sensor input (12Vdc to 48Vdc/50mA)
- 1 relay output (Max. 24Vdc/1A, 125Vac/0.5A)
Management and Software Update
- Configuration and system log can be accessed via Web browser and FTP application remotely
- Allows new firmware version updates via TCP/IP network
Channel Display (6 layouts)
Maximum 16 views
Recording Modes
- Manual Control
- Event-driven
- Scheduled recording
Playback Schemes
Date, Time interval, and event triggering with preview for every camera
Playback Control Modes
Play, Stop, Pause, Fast Forward, Slow Forward, Pull-bar, Zoom in, Zoom out
Standard
Data Rate & Modulation
- 22Mbps: PBCC
- 11Mbps: PBCC or CCK
- 5.5Mbps: PBCC or CCK
- 2Mbps: Barker
Operating Channels
- North America (FCC): 11
- Canada (DOC): 11
- Europe (ETSI): 13
- Japan (MKK): 14
Sensitivity @ PER<0.08
- 22Mbps < -80dBm (PBCC)
- 11Mbps < -84dBm (PBCC)
- 5.5Mbps < -86dBm (CCK)
- 2 Mbps < -89dBm (CCK)
- 1 Mbps < -91dBm (CCK)
Frequency Range
2.4 to 2.4835 GHz
Data Security
64, 128, 256-bit WEP (Wired Equivalent Privacy) encryption
Antenna
2dBi Gain internal patch antenna supporting diversity
Transmitter Output Power
15dBm +/- 2dBm
Range Coverage (Open Environment) *
- Indoors: Up to 100 meters
- Outdoors: Up to 300 meters
* Environmental factors may adversely affect operation range
תקנים
הורדות
DCS-5300W Pan/Tilt Internet Camera with 10/100BASE-TX Ethernet and 802.11b+ wireless LAN interface
