DCS-6511EOL EOS
מצלמת מעקב עם גוף עמיד עם אפשרות צילום לילי, מותאם להתקנה חיצונית בתקן IP66
תאור
Round-The-Clock surveillance
The D-Link DCS-6511 is a high-definition fixed dome day and night network camera, ideal for small-to-medium business applications and remote monitoring over the Internet. The camera employs a superior CMOS sensor with low lux sensitivity to deliver a truly superior image quality under varied lighting conditions. The DCS-6511 is equipped with a BNC video connector for an analog video signal, and DI/DO (digital input/digital output) connectors for external alarms and sensors.
High-quality video feeds
To maximize bandwidth efficiency and improve image quality, the DCS-6511 provides real-time video compression using the MJPEG, MPEG-4 and H.264 codecs. Furthermore, the DCS-6511 supports 3 separate profiles for simultaneous video streaming and is capable of recording in MJPEG, MPEG-4 and H.264 compression at 1.3 megapixel resolution. This kind of versatility enables a wide variety of security applications. For example, keep an eye on your home during lunch through a 3GPP enabled mobile device, or fine-tune your security system in real-time over the local network. You may also remotely manage a directory of recorded video files on a network attached storage (NAS) device or SD card.
Flexible installation
Power over Ethernet (PoE) connectivity allows for discreet installation in virtually any indoor location. This camera’s built-in 802.3af compliant PoE module eases the installation process by reducing the need to drill holes or lay additional cabling. In addition, the 10/100BASE-TX Ethernet port seamlessly connects to local network or to the Internet via a gateway router. This camera can be accessed and viewed from any network place as a device on the network.
Removable IR cut filter for  continuous monitoring
The ICR Filter can be manually applied via the web, or set to automatically adjust based on lightning conditions. This feature allows the camera to capture crisp color images during the daytime, and grayscale images in low-light conditions.
ePTZ for surveying regions of interest
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera’s mexapixel resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the mechanical lifecycle of the camera.
מאפיינים כללים
General specification
1/3” Megapixel WDR
Progressive Scan CMOS
WDR SN ratio: 100 dB
Motorized varifocal autofocus lens: 3.3 ~ 12 mm, F1.4 ~ F360C
View Angle
Vertical 63.6° (W) ~ 17.9° (T)
Horizontal 89.8° (W) ~ 23.9° (T)
Diagonal 125.7° (W) ~ 29.9° (T)
IR LED
20 meter illumination distance with 12
LEDs and light sensor
Minimum illumination:
Color: 0.2 lux @ F1.4
B/W: 0.02 lux @ F1.4
B/W: 0 lux with IR LED on
3-axis angle:
Vertical: 120
Horizontal: 340
Rotational: 300
System requirements
Operating System: Microsoft Windows XP, Vista, Windows 7
Internet Explorer 6 or above, Firefox 3.5 or above, Safari 4
Networking Protocol
IPv4, DHCP, ARP, DNS, TCP/IP, DDNS (D-Link), HTTP, HTTPS, UPnP™ Port Forwarding, Samba, SMTP, PPPoE, NTP (D-Link), FTP, RTP, RTSP, UDP, RTCP, ICMP, 3GPP
Built-in network interface
10/100BASE-TX Fast Ethernet
Video codecs
H.264
MPEG4
MJPEG
JPEG for still images
Resolution
(up to 30 fPS)
1280x1024
1280x720
640x480
320x240
160x120
Video features
Adjustable image size, quality and bitrate
Time stamp and text overlays
3 configurable privacy masks
Flip & mirror
ePTZ
Audio codecs
G.726
תקנים
הורדות
איורים
DCS-6511
מראה מקדימה
דף מידע
ראה גם
