חיפוש מהיר
תכונות המוצר:
מארז עם תמיכה PoE למצלמות DCS-5605
תאור:
D-Link’s DCS-71 outdoor dome housing series provide cost-effective protection and versatile connectivity
options for D-Link motorized pan and tilt surveillance cameras in outdoor environments. The DCS-71P model
facilitates Power over Ethernet (PoE) while the DCS-71W provides wireless connection for the security camera,
providing extra convenience in connecting and wiring surveillance cameras. A built-in power supply, heater
and blower mean these housings can be used under adverse weather conditions. Flexible Connectivity Options
The DCS-71P incorporates Power over Ethernet (PoE) in which electric power is transmitted over an Ethernet cable along with the Ethernet data. This allows the DCS-71P model to be easily installed in a variety of locations without the need for power cabling. The DCS-71W is equipped with wireless antennas that allow the camera to be controlled and
monitored wirelessly. This avoids the need to install Ethernet wiring. Weather-proof
Designed to be mounted outdoors, the DCS-71 housings feature an IP66 certified enclosure which protects against the elements including dust and heavy jets of water. Onboard Heater and Blower
The DCS-71 housing series also has an onboard heater and blower that enable the enclosed camera to function in a wide range of temperatures. The heater automatically turns on when the temperature is above a certain level and turns off only if the temperature drops below a certain temperature. The blower automatically turns at a certain temperature
and turns off only if rises above a certain point.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
