DCS-2210EOL EOS
מצלמת מעקב רשת עם תמיכה ב - Full HD ו H.264
תאור
24/7 Camera Surveillance
The DCS-2210/2230 Full HD Cube Network Camera is a versatile surveillance solution that is perfect for monitoring low-light environments in your home or small office. It combines a high-resolution 2 Megapixel sensor with a built-in IR LED to help you keep watch over areas in complete darkness. The DCS-2210/2230 also includes a built-in IR cut filter, making it suitable for both day and night applications. Additionally, the DCS-2210/2230 is a complete system with a built-in CPU and web server that transmits high-quality video images for security and surveillance. The DCS‑2210 includes support for Power over Ethernet(PoE), so the camera can be placed in areas where no power outlet is nearby. The DCS-2230 features 802.11n wireless, allowing the camera to be placed anywhere within range of your wireless network. The DCS‑2210/2230 also offers simple installation, an intuitive webbased interface, and remote monitoring and motion detection features for a complete and cost-effective home security solution.
Wireless N Connectivity (DCS-2230)
The DCS-2230 includes 802.11n wireless for fast and easy integration into your existing network environment. Wireless N allows you to stream highquality video to remote sites and mobile devices. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The DCS‑2210/2230 also includes a standard Ethernet port for connections to traditional wired networks.
ePTZ For Surveying Regions Of Interest
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera’s 2 mexapixel resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures.
Easy To Configure And Operate
This network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com), and remotely access the camera without having to remember your IP address. You may also view up to 32 cameras from a central location using the included D-ViewCam software. D-ViewCam has a robust set of features including automated e-mail alerts which can instantly inform administrators of suspicious or unusual activities.
מאפיינים כללים
Camera key features
• Progressive 1/2.7-dyuymovy megapixel CMOS-sensor
• The distance IR illumination: 5 m
• Minimum illumination: 0 lux with IR illumination
• Built-in ICR-filter
• Built-in PIR (Passive Infrared) sensor
• Built-in microphone and speaker
• 10x digital zoom
• Fixed focal length: 4.37 mm
• Aperture F2.0
• Angle:
  - Horizontal 67.4 °
  - Vertical 40.8 °
  - Diagonal 75 °
Functional videos
• Set the size, quality, frame rate and bit rate image
• Timestamps and paste text
• Windows to configure the motion detection
• 3 customizable private mask
• Customizable shutter speed, brightness, saturation, contrast and sharpness
Video compression
• Video compression formats H.264/MPEG4/MJPEG
• JPEG for still images
Video resolution
• 16:9 - 1920x1080 (up to 15 frames per second), 1280x720, 800 x 450 640 x 360 480 x 270 320 x 176 176 x 144 at 30 frames per second
• 4:3 - 1440h1080 (up to 15 frames per second), 1,280 x 960, 1024x768, 800 x 600 640 x 480 320 x 240 176 x 144 at 30 frames per second
Audio support
• G.726
Device interfaces
• Ethernet port 10/100 BASE-TX (with PoE for DCS-2210)
• Wireless interface 802.11n (only for the DCS-2230)
• 1 DI / DO 1
• Slot for Micro SD-Card
Network Protocols
• IPv4, TCP / IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding , RTP / RTSP / RTCP, IP filtering, 3GPP, IGMP, ONVIF
Security
• Protection of the Administrator account and user group
• Authentication by password
System control
System requirements for web-based interface
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event management
• Motion detection
• PIR-sensor for motion detection
• Event notification and download snapshots / video clips through HTTP, SMPT or FTP
• Support for multiple servers, HTTP, SMPT, FTP
• Multiple event notifications
• Several ways to backup
Remote management
• Setting up a web-browser
• Obtaining snapshots / video and save to your local hard drive or NAS via web-browser
Support for mobile phones
• Windows 7/Vista/XP, Pocket PC or mobile phone with support for 3GPP
System requirements for the D-ViewCam ™
• Browser: Internet Explorer 6 or above
• Protocol: TCP / IP
Software Features D-ViewCam ™
• Remote management / control of up to 32 cameras
• View images from 32 cameras on one screen
• Supports all management functions through a web-based interface
• Option to record the image sensor or manual operation
תקנים
הורדות
איורים
DCS-2210/Ax
מראה מאחורה
מראה מקדימה
מראה מימין
דף מידע
ראה גם
