DCS-3112EOL EOS
מצלמת מעקב רשת באיכות HD עם צילום לילי ותמיכה ב PoE
תאור
High Resolution Surveillance
The D-Link DCS-3112 is a high-end HD Day & Night Network Camera, equipped with a 1/4” Megapixel Progressive Scan CMOS sensor and a 3.5-8 mm DC auto iris lens. The camera can capture HD video at resolutions of up to 1280 x 720/1280 x 1024 with frame rates up to 30 fps. Snapshots and video can be saved to a network drive, or to onboard storage through the built-in SD Card slot.
Multiple Video Streams
The DCS-3112 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which require high image detail. H.264 and MPEG-4 produce a small file size, useful for extended recording or for use in low-bandwidth networks. Additionally, the DCS-3112 supports multicast H.264 and MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-3112 incorporates Power over Ethernet (PoE), which allows it to be easily installed in a variety of locations, even when no power outlet is nearby. The DCS-3112 also includes input and output ports that allow connectivity to external devices such as IR sensors, switches, and alarm relays. An RS-485 interface provides connectivity to an optional pan/tilt enclosure which effectively adds pan/tilt functionality to the DCS-3112. An additional 12 V interface provides power for an optional LED illuminator.
Smart And Easy To Use
The included D-ViewCam software allows you to view up to 32 cameras on a single computer screen from a central location. E-mail notifications can be sent whenever an event occurs, such as when motion is detected, if a camera is moved, or if a link to a camera is lost. Record snapshots and video automatically through motion-triggered recording, or according to a set schedule that you define.
מאפיינים כללים
Camera key features
• 1/4-inch 1.3 megapixel CMOS-sensor Sony Exmor
• Minimum illumination: 0.4 lux (Color); 0.04 lux (B & W)
• Built-in infrared filter
• 10x digital zoom
• Lens with variable focal length from 3.5 mm to 8 mm
• Aperture F2.0
• Angle:
  - Horizontal: 35,4 ° to 77,6 °
  - Vertical: 26,6 ° to 57,6 °
  - Diagonal: from 44,3 ° to 97,9 °
Functional videos
• Setting quality, size and speed of image transmission
• Timestamps and paste text
• Windows to configure the motion detection
• 3 private mask
• A custom white balance, shutter speed, adjust brightness, saturation, contrast,
Video compression
• Compression of video formats H.264/MPEG4/MJPEG
• JPEG for still images
Video resolution
• 16:9 - 1280 x 720, 800 x 450, 640 x 360, 480 x 270 320 x 176 176 x 144
• 4:3 - 1280 x 1024 1280 x 960, 1024 x 768 resolution, 800 x 600 640 x 480 480 x 360 320 x 240 176 x 144
Audio support
• G.726
External interfaces
• Port 10/100 BASE-TX Ethernet with PoE
• 2 DI / DO 1
• 12 VDC, 200 mA
• RS-485
• Slot for SD-Card
• Audio In / Out
• Video Output
Network
• Network Protocols: IPv4, TCP / IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding , RTP / RTSP / RTCP, IP filtering, 3GPP, IGMP, ONVIF
Security
• Protection of the Administrator account and user group
• Authentication by password
Systems integration
System Requirements
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event management
• Motion detection
• Event notification and download snapshots / video clips through HTTP, SMTP or FTP
• Support for multiple servers, HTTP, SMTP and FTP
• Multiple event notifications
• Several ways to backup
Remote management
• Setting up a Web-browser
• Obtaining snapshots / video and save to your local hard drive or NAS via Web-browser
Support for PDAs, mobile phones and software
• Windows 7/Vista/XP, PDA or mobile phone 3GPP
System requirements for the D-ViewCam ™
• Browser: Internet Explorer 6 or above
• Protocol: TCP / IP
Software Features D-ViewCam ™
• Manage / control up to 32 cameras
• View images from 32 cameras on one screen
• Supports all management functions through a web-based interface
• Option to record the image sensor or manual operation
תקנים
הורדות
איורים
DCS-3112/Ax
מראה משמאל
מראה מאחורה
מראה מימין
דף מידע
ראה גם
