חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת עם תמיכה ב FullHD ו PoE
תאור:
IP-Dome Camera D-Link DCS-6112 provides high-definition video transmission and compression format H.264, that can record high-definition video. When you connect to the network camera provides high quality video transmission over the Internet. The internal 3-axis swivel bracket provides a choice of direction of view. The supplied software allows you to view high quality images up to 32 cameras on one computer screen in real time. The camera is also equipped with a slot for MicroSD-card, which is used for local backups of important events.
High definition video surveillance
The DCS-6112 supports Full HD resolution and enables you to capture video in widescreen mode (16:9), which provides high quality video and simplifies viewing and video surveillance.
Support for multicast data
To increase the efficiency of bandwidth utilization and to increase the image quality the camera DCS-6112 uses streaming video compression formats: MJPEG, MPEG-4 and H.264. Data compression is H.264 produces small files, which is useful for long-term recording, or in networks with low bandwidth. MJPEG format provides file integrity, making it ideal for situations that require high image detail. The camera can organize the multicast data stream and provide access to video on demand.
Extensive connectivity
The DCS-6112 is equipped with inlet and outlet ports for connection to external devices such as IR sensors, switches and alarm relays. The DCS-6112 supports Power over Ethernet (PoE), eliminating the need for laying power cables.
View the video in real time on a mobile phone 3GPP
The DCS-6112 allows you to view the video stream from a compatible mobile phone. This significantly extends the capabilities of monitoring, allowing users to monitor without a PC.
Detection of tamper attempts (Tamper Detection)
Resistant building the DCS-6112 provides protection against intruders and allows you to place the camera at the intersection of transport and communications, schools and prisons. The camera is equipped with electronic alarm system that uses a visual or audible alarm when you change position and focus the camera, as well as blocking or spray-painting.
Centralized control via D-ViewCam
Software D-ViewCam ™ D-Link, included in the package, allows you to view up to 32 cameras on one computer screen. Users can set up automatic notification by e-mail to be instantly informed of unusual activities, to create a recording schedule, as well as the Detected record video directly to hard disk. Software D-ViewCam ™ also allows you to download the floor plan of the enterprise and create a layout of cameras, which greatly simplifies the process of governance.
Viewing window and functions ePTZ
The user can select the required area for viewing (Region of Interest (ROI)) on the screen in the Web-interface. The ability to move the field of ROI is an advantage for cameras with fixed focal length, as this function can be used in conjunction with virtual pan settings, preset positions, which provides high-quality video. Viewing window also allows you to use the zoom function for more detailed images.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
