חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת עם חיישן WDR עם צילום לילי עם תמיכה ב FullHD ו PoE
תאור:
High definition video surveillance
High-performance 3-megapixel camera DCS-3716 to conduct day / night camera equipped with 1/2 ,8-inch CMOS-sensor with progressive scan technology, as well as a lens with a focal length of 3.1-8mm auto iris. The DCS-3716 enables you to capture video in low light, and illumination of objects in the rear. In addition, ICR-filter allows you to receive high-quality video at any time. DCS-3716 is equipped with a slot for SD-cards. Interface Power over Ethernet (PoE), allows you to place the camera in various locations.
Multiple video streams
To increase the efficiency of bandwidth utilization and to increase the image quality the camera DCS-3716 uses streaming video compression formats: MJPEG, MPEG-4 and H.264. MJPEG format provides file integrity, making it ideal for situations that require high image detail. Data compression is H.264 and MPEG-4 allows you to get small files, which is useful for long-term recording, or in networks with low bandwidth. The camera can provide access to video on demand.
Extensive connectivity
DCS-3716 is equipped with inlet and outlet ports for connection to external devices such as IR sensors, switches and alarm relays. The camera is also equipped with RS-485 interface for connecting external devices, pan / tilt. In addition, the interface 12 provides power to the additional LED-light source.
WDR technology
Technology WDR (Wide Dynamic Range) provides a clear image even in backlight when the light intensity may change significantly. The DCS-3716 can be successfully applied in environments with high contrast. For example, while inside, the camera DCS-3716 allows you to monitor conditions in the intense sunlight. Thus, the DCS-3716 camera is the ideal solution for security applications.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
