חיפוש מהיר
תכונות המוצר:
שרת NVR עם מקום ל 2 דיסקים
מאפיינים כללים:
Standards
• IEEE 802.3/u/z
• Auto MDI / MDI-X
• SATA I, II
HDD (Hard Disk)
• Control and management of the hard drive via a PC
• Reformatting the disk
• RAID 0, 1
• JBOD
Security
• Castle (HDD)
• Safety Lock (device)
Performance
Flash ROM
128 MB
RAM
256 MB DDR II
Network Interface
Port LAN Gigabit Ethernet (10/100/1000 Mbit / s)
I / O Ports
• RJ-45 port
• DC-in jack
• USB port for updating the status of the UPS
Software features
Operating system: Linux
Supported Cameras
• Supports all network cameras D-Link. Includes support for automatic detection and megapixel resolution
• Supports network cameras of renowned brands, including D-Link, Axis, Panasonic, Sony, Mobotix, Arecont Vision, IQinVision, Cisco, and Acti
Performance record
• Max. characteristics (mode only NVR):
- H.264 1080P (baud rate): 90 Mbit / s
- H.264 720P (baud rate): 90 Mbit / s
- MJPEG 1080P (frame rate): 90 frames / s
- MJPEG 720P (frame rate): 192 frames / s
• Max. characteristics (mode NVR + File Server):
- H.264 1080P (baud rate): 68 Mbit / s
- H.264 720P (baud rate): 68 Mbit / s
- MJPEG 1080P (frame rate): 70 frames / s
- MJPEG 720P (frame rate): 150 frames / s
Search for the camera
UPnP
Record audio and video
Record synchronized audio and video
Compression Format
H.264, MPEG-4, M-JPEG (on supported cameras)
Setting up video
Resolution, quality, frame rate, add audio, go to the camera interface
Type of record
Scheduled recording, manual or event-driven (DI-trigger, motion detection sensor of the camera)
Remote viewing of live video
• Remote viewing of live video via Internet Explorer
• The maximum number of simultaneous channels viewed: 9
Managing remote video in real time
View the video in real time, preset / switch (preset / go), patrolling, focus, function PTZ (pan / tilt / rotation), freeze-frame, full-screen mode, digital zoom
Managing remote playback
• Play with the normal functions of rewind, fast forward / backward and step forward / backward
• Intelligent detection Smart Search: General Motion (basic movement), Missing Object (missing object), Foreign Object (foreign object), Camera Occlusion (Blackout camera), Lose Focus (Losing focus)
Remote playback
• Remote playback through Internet Explorer and NVR-client
• The system of play with the timeline graphical user interface, search by event, area, cameras, date and time
• Internet Explorer and the NVR-client supports simultaneous playback of four channels
Function rewrite
Auto recycling when filling the space on your hard drive
Exporting files
• Export of video files in AVI format or ASF
• Export images in BMP or JPG
A user account
Ability to create additional user accounts to allow users access to the system, as well as authorization for the determination of channel cameras, PTZ, etc.
DDNS
Support DDNS-server D-Link
Two modes reset to factory settings
• Reset the firmware to factory settings through the GUI
• Push hard reset to factory settings (you need to hold for 5 seconds)
System time
Setting the system time (D-Link NTP, time entry, sync with your computer, saving time)
Remote backup
• Remote software can create a backup copy of the raw data on a secondary storage device
• Backing up data to a remote FTP-server on a daily schedule
System Status
• Position the camera
• System Status
Network Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP-server
• DHCP-client
• NTP-client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• HTTP-server
• PPPoE
• UPnP
• Filtering of IP-addresses
• Samba-Server
User interface
• Web-browser HTTP
• Internet Explorer 7 or later
• NVR Search Tool
• Multi-language graphical user interface
Delivery
• Network DVR with two drive bays
• Power Adapter
• Ethernet-cable
• Quick Installation Guide
• The holder of the power cable
• CD-ROM with software and documentation Product
נתונים פיזיים
Power adapter
• 12 V DC / 4 A
Maximum power consumption
• 25.20 Watts
Maximum power consumption in standby mode
• 0.234 Watts
Operating temperature
• From 0 ° to 55 ° C
Storage temperature
• From -20 ° to 70 ° C
Humidity
• From 5% to 90% (no condensation)
Dimensions
• 115 x 146,4 x 178,5 mm
Weight
• 0.875 kg
Certificates
• CE
• FCC
• RoHS
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
