חיפוש מהיר
תכונות המוצר:
מצלמת מעקב חיצונית עם אפשרות צילום לילי באיכות Full HD עם חיישן WDR
מאפיינים כללים:
Characteristics
• 1/2 inch, 8-megapixel CMOS-sensor with progressive scan technology
• Infrared light: lighting range - up to 30 m
• Minimum illumination: 0 lux with IR lighting
• Built-in ICR-filter
• 10x digital zoom
• Focal length: 3.9 mm
• Aperture: F1.2
• Viewing angle (16:9):
  121,2 ° - 38,1 ° (horizontal)
  62,1 ° - 21,3 ° (vertical)
  148,4 ° - 43,8 ° (diagonal)
Camera Body
• Weatherproof housing (standard IP-66)
• Bracket for cable
Functional video
• Adjustable image size and quality, frame rate and data
• Timestamps and paste text
• Customizable windows for motion detection
• Private mask
• Set the shutter speed, brightness, color saturation, contrast, sharpness, zoom, focus and iris
Video Compression
• Simultaneous compression formats H.264/MPEG-4/MJPEG
• Multicast streaming video formats H.264/MPEG-4
• JPEG for still images
Video Resolution
• 16:9 - 1920 x 1080, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 frames / s
• 4:3 - 1440 x 1080, 1280 x 960, 1024 x 768, 800 x 600, 640 x 480, 320 x 240, 176 x 144 up to 30 frames / s
Audio support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet with PoE
• 1 DI / 1 DO
• Output 12 VDC, 100 mA
• Card slot for SD / SDHC
• Audio-vhod/vyhod
• The connector DI / DO
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering of IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• ONVIF
Safety
• Security Administrator and user group
• Password authentication
• Encryption HTTP and RTSP
System requirements for Web-based
Web-browser: Internet Explorer, Firefox, Chrome or Safari
Event management
• Motion detection
• Event notification and download stop-kadrov/videoklipov by e-mail or FTP
• Support for multiple FTP and SMTP servers
• Multiple event notifications
• Several ways to backup
Remote management
• Creating and maintaining stop-kadrov/videoklipov to a local hard drive or NAS via Web-browser
• Setting up a Web-browser
Operating system
• Windows 7/Vista/XP/2000
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
Software features D-ViewCam ™
• Remote control
• Monitoring / control up to 32 cameras
• View images from 32 cameras on one screen
• Supports management of Web-based
• Recording Option detected image or manually
נתונים פיזיים
Weight
• 2.05 kg with bracket and sunshield
External power adapter
• Input: 100-240 VAC, 50/60 Hz
• Output: 12 V, 1.25 A
Power consumption
• 11.02 W ± 5%
Temperature
• Operating: -40 to 50 C
• Storage: -20 to 70 C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• CE
• CE LVD
• FCC
• C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
